Results 1 to 10 of 22
Thread: Puma 2.2 Engine oil, where it at?
    Sep 2015
    ACT
    Merry Christmas Brains Trust,
    I have been reading some threads on what type of oil is suitable for the 2.2 but cant find anything conclusive on where and what type of oil can be readily found at the regular outlets ie Repco, Autobahn and Supercheap.
    Getting my new 90 soon and just want to be able to source something within spec for any changes I may want to do in between my 20,000km oil changes. I usually go by how it looks in terms of whether its still translucent before it becomes completely soot laden. Really depends on how hard it has been working in between that service period. I will be disconnecting the EGR to avert any premature black stuff aswell.
    Is there anything you guys have been sourcing with relative ease? Furthermore, is the 'Australian' model fitted the DPF?
    Thanks in advance.
    Dec 2012
    Snowy Mountains
    Penrite do the full range of required specification oil/s.
    REPCO and Supercheap have ample supplies.
    I run the 5W40 HPR Diesel in mine for the last 100,000 km with no issues or usage.
    The HPR diesel is OK as the Pumas in OZ don't have a DPF.
    Sep 2015
    ACT
    Quote Originally Posted by ozrob View Post
    Thanks, not having the DPF will make it easier/cheaper. Cheers!
    Jun 2013
    I have switched to Penrite HPR5 full synthetic. This has the requisite specs
    (WSS-M2C913-B or C) for the 2.2 non DPF
    Penrite HPR diesel is semi-synthetic and doesn't have the magic spec numbers
    Neil
    (Really shouldn't be a...) Grumpy old fart!
    MY2025.5 110 D250 S MHEV (L663)
    In Memoriam:
    MY2013 110 TDCi DCPU purchased new from Land Rover Malaysia in May 2013.
    ...traded in for the above L663 in December 2025.
    Nulla tenaci invia est via
    Sep 2015
    ACT
    Ok cool, that is easily accessible. Thank you.
    You do at 10k?
    May 2003
    On The Road
    20K?
    (well,, at least thats down from 26K,,)
    Do you also believe in gearboxes filled for life?
    Sep 2015
    ACT
    Cool
    20K?
    I got free servicing for 3 yrs, pretty sure they push it out to 20k for engine oil on plan. Every 2 yrs for driveline lubes with me thanks, unless dipped in water then who knows!
    Brisbane,some of the time.
    Synpower FE 5w-30 can also be used(Valvoline)
    Available everywhere in 5L.
    I would find out what the stealers use and then if available use the same.Better not to mix oils if you don't have to,and helps if any warranty issues.
    Jun 2013
    Quote Originally Posted by AlecW View Post
    You do at 10k?
    Yeah it might be overkill - but I do 10k oil changes.
    Neil
    In Memoriam:
    NSW far north coast
    Quote Originally Posted by tact View Post
    With your humidity, so would I.
    You'll probably find 20,000km is 'normal' use in a temperate climate. (read Europe)
    High humidity, dust, heat, stop/start city driving, off road use, towing, all bets are off and the oil change interval comes back.
