Results 1 to 6 of 6
Thread: station wagon rear window demister
    does anyone have a wiring diagram for the rear door demister as fitted to station wagon doors?
    or have an operating demister which works?
    I have a demister fitted to the rear door, but no wiring to it and would like to make it work, but not game to connect 12 volts directly to it as I may blow it up, I presume there is a resistor in the system.
    and merry Christmas to all.
    Safe Travels
    harry
    bump
    Safe Travels
    harry
    May 2015
    Southern Adelaide
    Gold Coast QLD
    If you run 12volts through the 10 amp scale on your meter and use alligator clip probes, you will be able to see how much current it draws on the meter and you should be able to disconnect it before it grenades if there is a problem, I fitted one many years ago to a Torana
    And there was no resistor in the circuit. Maybe meter out the heater first on ohms, and calculate how much current it should draw before wiring it up through the meter.
    1964, S2a SWB "Ralph"
    1977, S3 SWB "Smeg" (Gone)
    1996 D1 300tdi auto (Gone)
    1973 Rangie Classic (Gone)
    2012, 110 (Series 12) Puma "The Tardis"
    1962 109" Tray Back "Ernie"
    1998 D1 300tdi (Dizzy)
    2017 Kawasaki Versys 1000
    You must now cut down the tallest tree in the forest... With... A HERRING!!!!!
    Thanks for that, I will take some resistance measurement first, obviously it need s some resistance to warm the window but there must be a critical number before it burns out....
    Safe Travels
    harry
    JDNSW's Avatar
    I was not aware that the demister was ever an option on the 2a, but I assume it is the same as the ones on the 110 - operates direct on 12v, same as every other one I have ever seen.
