Thread: strange electrical issue
    Sorrento Victoria
    I've got a strange electrical issue with my perentie - when i put my foot on the brake pedal my voltmeter reading drops signicantly? Also my water temp gauge won't go above around 60 degress-may be faulty thermostat but thought it might be all related?
    Geelong, VIC
    In my experience 99% of weird electrical issues when you put your foot on the brake pedal are related to earthing issues.
    I'd start by looking at any earth points that are shared between instruments and lighting.
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    Hay Point
    Quote Originally Posted by steveG View Post
    Steve
    X2. Definitely sounds like an earth problem.
    Cheers......Brian
    1985 110 V8 County
    Jun 2014
    Waitakere, New Zealand
    When I use the brake pedal my park lights come on haha
    Sent from my Nexus 4 using AULRO mobile app
    Feb 2013
    Sunshine Coast
    Quote Originally Posted by BadCo. View Post
    Your problem is a bad earth, most likely at the tail lights themselves.
    As for the OP's situation; the voltmeter and brake lights don't share an earth path, so it is more likely the problem is supply side. I don't have the schematic with me, but from memory brakes and gauges share a fuse. My guess is that your problem will be there - make sure the fuse is tight in the holder and that there's no corrosion.
    Jun 2014
    Quote Originally Posted by Dervish View Post
    I'm 100% sure its the poor fittings themselves. I have not bothered to fix them because I'll change to LED fittings later.
    Its just amusing the electrical issues you get with these trucks haha.
    Mar 2015
    Quote Originally Posted by mattmac View Post
    I have the same issue with the voltmeter. I've checked and cleaned the earths and fuses - still does it. I ignore it now.
    Regarding your temp gauge, it could be either the gauge or the temperature sensor.
