I'm not at home with mine so can't measure the tube to ground hight.
I can check it if required latter.
What I can tell you is with the standard LR rated drop down tounge the tow ball mounting flat on mine is @500mm.
I needed 500mm+/-50mm as this was checked for our camper hitch hight.
