Thread: Wall Wart Question
    May 2009
    Tatura, Vic
    Wall Wart Question
    I have a 24 volt ac christmas decoration that the wall wart has died.
    It has on it "Output 24V Max 10VA"
    What does 10VA mean? I rang Jaycar and they did not have one.
    There are plenty on ebay but they just list volts and amps, not VA.
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    Jul 2009
    Hobart
    Hi,
    If 10 = 24 x A
    then A = 10/24
    so it will be less than 1/2 an Amp, or 500mA.
    Western Victoria
    It's just another way of expressing power i.e. Watts.
    Watts and VA are similar but with AC the values are slightly different.
    Here's a 20VA unit:
    http://www.ebay.com.au/itm/POWER-SUP...-/262086694970
    May 2009
    Tatura, Vic
    Thanks guys.
    So Mick, in the link you posted it says 20 VA .8amps
    So would that mean mine being 10 VA be .4 amps?
    Dave.
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    Jul 2009
    Hobart
    Hi,
    0.416666667A, but I'm not being sensible.
    Western Victoria
    Quote Originally Posted by d2dave View Post
    Thanks guys.
    Yep.
    It's also AC, so not a DC plug pack. A DC plug pack may work.
    I'd get that 20VA unit and wire it up.
    May 2009
    Tatura, Vic
    Thanks Mick. I purchased two of these, being so cheap I got a spare.
    This should do the job shouldn't it?
    DC 24V 1A AC Adapter Charger Power Supply FOR LED Strip Light CCTV 2 5mm 5 5mm | eBay
    Dave.
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
