'Best' is a bit subjective.
If I had all the dollars in the world, I'd love a modified unimog setup. Or do something tricky with the dana diffs that come in a crate from the states.
Plenty of people here are using stock diffs with ARB / Harrop e lockers.
Can you elaborate what you mean by your current diff is 'done'? The lockers are just the centre (not the ring and pinion gears) which means if you've got other issues, the issues will still be there once you get locked.
and have never done so many diffs in my life) Once ya put new bearings and half the time a new crown wheel and pinion, only because once you get the diff whining away for a bit it puts a new wear pattern on the C & P.
