Results 1 to 10 of 39
Thread: Why cant people use the door handles?
    cafe latte Guest
    I have been looking for a 300 tdi Defender for a bit now, not all but many of them have dents above the doors handle caused by people slamming the door closed by pushing the door panel instead of the handle, WHY!! I have a Nissan patrol with a faded patch of paint where the previous owner did the same thing, how hard is it to use the handle? I have just looked at a pic on car sales, I was not interested in it as it is a td5 and I want a 300tdi, but EVERY door in the car had the same big dent over the handle, a whole family of door pushers it seems!! Most annoying is when people do it to your car, the father in law is a door pusher, you are unloading shopping and he comes to help nooooo!!!
    You guessed it my pet hate
    Chris
    NSW far north coast
    Chris, good luck finding one without a few, err, character lines.
    Remember that anything pre Tdci uses aluminium door skins that ding just from a light breeze too.
    My ex used to say that the Defender is born middle aged as it comes from the factory with cellulite.
    She was a Patrol driver though.
    cafe latte Guest
    I dont mind character marks, but even if the doors where steel pushing the panel shut especially if the door does not shut correctly the first time will dent the door. If I find a good car like this I will fix the panel it will not be a deal breaker for sure, I just cant understand why people do it.
    Chris
    Sep 2013
    toowoomba
    I paid the 50k+ for it, i'll shut the doors however and as hard as i like
    cafe latte Guest
    Quote Originally Posted by komaterpillar View Post
    Not twice on my car you wouldnt, part of the problem people do it on other peoples cars too.. Bit like those in supermarkets who open their doors and slam into your door, they may not care about their car but it is bang out of order damaging someone else's.
    Chris
    Edit.. And why would anyone do something that is obviously damaging their gear/car whatever it is. You see what you are doing is causing damage you need to be some kind of idiot to keep doing it when there is a handle so close by and what it is there for..We go off roading and damage are trucks doing what they are designed for, dings and bumps arrive with normal use, but why do something that for sure causes damage? You may as well buy the car new and hit all the doors with a hammer over the handle to get that flat spot started.
    How do you close the bonnet on your vehicles?
    i discovered recently that the technique I had been using for about 40 years without incident is the wrong way to do it.
    May 2014
    Tamworth NSW
    Quote Originally Posted by vnx205 View Post
    I Lift the bonnet about 200mm up from the catch, and drop it. It sounds horrid, but is the best way I was told (so you don't ding it).
    -Mitch
    'El Burro' 2012 Defender 90.
    About 100mm seems to be enough for my bonnets.
    Dropping the bonnet from a suitable height is the way i read it should be done for the reason you mentioned.
    Maybe some of us used to do it the other way because we started driving when cars had panels that were difficult to dent with a sledge hammer and were in no danger of being damaged with your bare hands.
    Avoca Beach
    I can recall looking at new 110s at Trivett Classic when we had Range Rover Club meetings there in the early 2000s.
    Every one of them had dents in the doors where the door handles attached, and I believe it was from the support panel not being flush with the skin.
    I thought it quite Land Rover like that 110s were sold pre dented so that this saved the new owner the bother of DIY. LOL
    So Maybe don't be so harsh.
    AFAIR they may have fixed this on Pumas.
    Regards Philip A
    NSW far north coast
    Quote Originally Posted by Toxic_Avenger View Post
    I can't just drop the bonnet on mine as the catch hits the edge of the striker plate, I have to push it back a touch towards the firewall and then push the bonnet closed.
    Any other car I just drop.
