Results 1 to 8 of 8
Thread: Gems intake plenum question
    May 2015
    Victoria
    When I took apart intake plenum the upper seemed to be glued to lower. I am currently refitting upper intake plenum to lower. What type of glue / sealant do I use?
    Feb 2013
    Gosford, NSW, Australia
    Hi
    I used permatex anaerobic flange sealant, as per Ron's suggestion
    Others have used Hylomar as per RAVE
    Steve
    Nov 2015
    Perth W.A. (Gidgegannup).
    G'day Anthony.
    Wot Steve said! I used Pirtek brand anaerobic hydraulic pipe thread sealant (coz I already had it).
    So I'm sure any similar fit for purpose product will be fine.
    Cheers, Timmy.
    Last edited by P38 4.6 Timmy; 11th January 2016 at 02:12 PM. Reason: I used PIRTEK..not PERMATEX..damn auto spelling thingamajig!
    May 2015
    Victoria
    Cheers Timmy,
    Is Spray Hylomar ok?
    Nov 2015
    Quote Originally Posted by Anthony Violi View Post
    Cheers Timmy,
    I wouldn't recommend it myself, the spray stuff is more for using with conventional gaskets as far as I understand. I used to use it on cylinder head and base gaskets when doing top end rebuilds on 2 stroke dirt bikes. I don't believe it would be the best product for metal to metal as it remains a bit flexible.
    You want an "anaerobic" fully setting sealant..like you said, when you remove the plenum, it's like it's been glued on
    That's my experience and understanding anyway...I have been wrong tho...once..that was when I married my now ex wife
    Cheers, Timmy.
    Jan 2012
    Bendigo
    I used a loctite anaerobic sealant, worked really well.
    Sent from my SM-G900I using AULRO mobile app
    May 2015
    Victoria
    Purchased permatex anaerobic gasket maker. Is this the right stuff? Instructions says I need permatex spray surface prep activator. Is this correct?
    Nov 2015
    You don't have to use the activator/accelerator, it's mainly for use in very cold weather or if you need to speed up the curing time. In our lovely Aussie weather it's fine without it.
    Cheers, Timmy.
