Results 1 to 2 of 2
Thread: D4 rear hatch problems
    Good morning all, having a problem with the D4 rear hatch release. I've read the posts so far but cant point to whats wrong with mine. It has jammed closed before but following liberal WD40 & grease, etc. It now opens but only after 2-3 clicks of the handle. Cable looks fine. Any clues as to which part need replacing?
    2011 SDV6 3.0L + Torus Kakadu, Winchbar, UHF, roof racks, 1 wife, 4 dogs, not enough fishing rods, and Wallabies supporter.
    LRD414's Avatar
    Oct 2014
    Assume you mean the upper tailgate latch?
    If so, sounds the same as James. His cable was ok but the electric actuator started to fail until eventually it stopped altogether.
    Has the actuator noise changed, perhaps sounding more laboured? Is it better with the vehicle running, when it has a higher voltage available?
    If this is your issue, better to replace the actuator now before the tailgate gets stuck in the closed position. It's not very expensive or too difficult with the tailgate open.
    http://www.aulro.com/afvb/d3-d4-rrs/...ease-d3-6.html
    Regards,
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
