Results 1 to 8 of 8
Thread: Td5 won't start - fuel pump / Electronics? North ADL
    Sep 2013
    Unhappy Td5 won't start - fuel pump / Electronics? North ADL
    Evening all,
    So today after driving to work no worries this morning, later when I went to start the Defender it initially started and then stoped after a couple of seconds, and now just turns over and won't start..
    After talking (offline) with blknight.aus I've run through some basic fault finding including fuses, relays, inertia switch but I'm not getting anywhere. I think it must be the fuel pump, but one thing leads me to believe it could be other electronics somewhere - the glow plug lights won't come on at all..
    As I've already paid for the service I called the RAA, the bloke was nice but couldn't really do anything - even his ECU reader wouldn't talk to the NNN TD5 ECU. He's given me a deferred tow so I need to decide where to send it.
    Having just moved to Adelaide I'm not sure if I should send it to a auto elec or try for a Land Rover place, or possibly get it towed to my place and have a go at the fuel pump.
    Anyone have any suggestions for Land Rover services in Northern Adelaide?
    Thanks,
    Matt
    '04 Defender 90
    Sep 2012
    Adelaide Hills
    Shaun at boostworx looks after all my land rover needs.
    He's owned several including a td5.
    He's near gepps cross
    Current Cars:
    2013 E3 Maloo, 350kw
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    2002 VY SS Ute, 300kw
    2002 Disco 2, LS1 conversion
    Sep 2013
    Thanks Eevo,
    I've contacted a couple of the members off the Adelaide members with diagnostic equipment map to see if I can narrow it down before deciding what I do.
    Matt
    '04 Defender 90
    alien's Avatar
    alien is offline A Keeper of the TGO Silver Subscriber
    Bacchus Marsh Vic.
    I've just looked at a D2,TD5 with the same symptoms as yours.
    The fuel pump is ticking over but very quiet.
    Power relay was swaped and power feed checked, no change.
    Uncliped the fuel line at the FPR and ran it into a bottle , turned the key and no flow at all.
    We think this pump is less than 12 months old
    Cheers, Kyle
    The Good Oil.
    When did you last visit?
    Sep 2013
    Quote Originally Posted by alien View Post
    I think with the key in pos 2 the pump isn't going, but with the relay bridged i can hear it quietly, would have to confirm..
    Is the glow plug light behaving as normal? The fact it's not coming on is the only thing that's throwing me off from ordering a new fuel pump and getting it towed to my house to work on..
    Matt
    '04 Defender 90
    Sep 2013
    Just to close the loop on this one, it turned out to be a faulty ECU...
    During the fault finding process it was discovered that the ignition switch was faulty/intermittent. I'm hoping this is what caused the ECU to go.
    Thanks for the replies.
    Matt
    '04 Defender 90
    Quote Originally Posted by md90 View Post
    What mileage if I may ask?
    Not keen on my ignition barrel playing up in the middle of nowhere.
    Max P
    Sep 2013
    2004 Defender 210,000 KM.
    The part actually goes on the back of the ignition, and is just the electrical switch component. 4 Heavy wires attach to the back. When inspecting it, touching the wires caused chattering, and trying to take a spade terminal off the whole thing fell apart.
    Part is $30 - PRC8230 for the td5.
    Matt
    '04 Defender 90
