Results 1 to 10 of 14
Thread: Coromal 580 Seka
    Williams West Aust
    Coromal 580 Seka
    Anybody have any experience with these????
    May look at this one,depending how much over $15000 the seller is willing to pay for my boat,its also listed as a trade for a boat.
    Coromal seka 580 | Caravans | Gumtree Australia Rockingham Area - Rockingham | 1098529883
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Apr 2015
    Bouvard, WA (near Mandurah)
    Thumbs up
    Andy,
    I know a little, the Coromals have aluminium frames so rot is less likely an issue and are generally lighter.
    The Coromal independent suspension is normally a knee type and may require leaf spring replacement when it gets older. See the link below.
    http://hardingscaravans.com.au/carav...ns-we-service/
    Although the description gives the indication that things have been maintained.
    This post has an interesting conversion. Graeme may be able to tell you what to look for on the suspension.
    http://www.aulro.com/afvb/trailers-v...onversion.html
    In general other questions to consider,
    1. Will 1 deep cycle battery be adequate for your needs.
    2. Will you need Solar panels?
    3. Will you need a built in toilet and/or shower? (Compulsory for my purchase)
    4. Will you be converting to LED lighting? (Unless already done)
    5. Are you sure you really want a pop up? Extra time on set up, not owned one but was aware of the extra time compare to full size van. Having helped others who have one.
    6. Will you need and does it have an AC? (Compulsory for my purchase, main reason for moving on from tents)
    7. Gas HWS? I would check if it has 240V as well. In powered sites you may end up using your own gas for HW?
    8. It describes extra water tanks but does not state the number and volume.
    Like buying a boat I started looking with a budget and ended up spending much more as I found out more about the various bits and pieces. I intend to keep our van for around 5 years minimum.
    Craig
    2015 Discovery 4 HSE SDV6
    2013 Nova Terra Sportz 22' van
    2007 Sea Ray 185 Sports Bowrider
    Specialised 29" Rockhopper
    Williams West Aust
    Cheers Craig
    I have 2x200w panels in the shed I bought for the camper trailer,I also have 2x120amp deep cycles on the trailer I would transfer over,always intended on a inverter/solar panel controler/240V charge in unit for the CT,so would do the same,plus update lighting to LED.There is also a water tank on the camper trailer to swap over.The one Im looking at is a tandem.
    I saw a smaller poptop with a ensuite conversion,which would have to happen I think.
    They would need to come up with at least 5K in the swap.I dont mind a project.
    Andrew
    Apr 2015
    Andy,
    OK, all is in hand then.
    But do you (in particular the better half) really want no Air cond? I now see it states no AC.
    Craig
    NSW SW Slopes
    The top of my 1990 Coromal pop-top takes only a minute to raise but does require some effort, which recently I thought was getting beyond me until my son couldn't lift it either until I released the 4th catch! Later ones most likely have a lever system that requires much less effort.
    The Coromal suspension can't satisfactorily be raised other than re-instating original height if the springs are sagged because the camber changes dramatically.
    May 2003
    On The Road
    Andy, think carefully about buying a popup if you're having back problems,
    NSW SW Slopes
    That Coromal doesn't have levers to raise the top, being the same as my 14'. I understand that the springs or perhaps the whole mechanisms can be replaced to re-instate the original effort to lift as the springs stretch over time.
    Edit: I see that the struts have been recently replaced.
    Williams West Aust
    Pedro.
    The main want for a pop top is the reduced towing height,and more so the airflow thru the canvas section,I would prefer that to aircon.
    I saw one listed yesterday with air struts and a compressor to lift the top,that sort of conversion wouldnt be beyond me.
    Andrew
    Williams West Aust
    This van wont be happening.Thanks for the info.I learnt something here re-the suspension on a Coromal.I will start another thread on suspensions,interested to learn what is under what.
    Andrew
    NSW SW Slopes
    Off-road Coromals have a larger and heavier duty version of the same suspension so those vans might be a better proposition.
