Results 1 to 10 of 11
Thread: Query re Mulgo Gas Strut
    Mar 2010
    QLD
    G'day all,
    After a few months now of using Mulgo's gas strut I've got a query for the masses.
    Firstly, there appears to be quite a bit of flexing of the panel in the car where the mount is bolted. This piece is bolted on top of carpet and soundproofing, although it's is very securely fastened. Should I expect this flexing, and is it okay, or do I need to take steps to minimise it? And if the latter, what?
    Secondly, when I open the door I do so gently. When my wife opens the door she does not. I've noticed very slight marks on the right quarter panel that appear to be dots from the new spare marking the dust on that panel. This means the door is swinging some way past the 90 degrees that I had set it to. Again, is that normal, or should I make some changes?
    Cheers guys.
    Oct 2014
    Perth W.A
    Yes, I agree the side panel flexes lots!
    I dont (yet) have the Mungo strut, but I think the standard strut attachment panel needs some reinforcement behind the panel, in the wheel arch area...
    Has anyone had the wind catch the rear door and rip/bend the attachment point off?
    Jun 2015
    Vic
    Quote Originally Posted by YOLO110 View Post
    I've got a strut still new in the box you can have for $100? I've decided to go down the rijidij carrier route instead.
    Oct 2014
    Perth W.A
    Quote Originally Posted by barkingmad View Post
    PM sent.
    Nov 2015
    Adelaide Hills
    Quote Originally Posted by jc109 View Post
    G'day all,
    Cheers guys.
    Hi JC109,
    I've had the gas strut mounted on my 110 for 40,000kms, and haven't had to modify the mount. Seems to be going strong...so far!
    As for the marking on the rear quarter, it's definitely there. Like you said though you do need to accompany the door when you open it otherwise I reckon there will be a bit of denting over time.
    So overall yes all this is normal
    Nov 2015
    Adelaide Hills
    I haven't had any dramas with damage to the attachment so far, having said that though I am very aware of accompanying the door open in strong winds until the spare is resting against the rear quarter panel
    Nov 2015
    Adelaide Hills
    Photos always help...
    Mar 2010
    QLD
    Champion. Thanks Black 110. I'll just keep an eye on it then.
    I'll eventually get myself one of Rijidij's carriers so that should prevent one of these two issues, at least.
    Jul 2009
    Melbourne, Victoria
    I found out the hard way with my last Defender when a gust of wind on top of Mt Wellington in Tasmania ripped the door from my fingers as I started to open it and swung it into the quarter panel causing a dent in the panel. Even with normal opening or slight side angles you have to be careful not to let it swing too wide. Every second Defender has the tell-tale dent in that panel, and it won't pop out as the aluminium gets stretched.
    Larger diameter tyres would cause an even bigger problem.
    I think it needs further reinforcement in the arch area to help reduce flex with the standard Land Rover strut and is one of the jobs on my list to do.
    Obviously wheel carriers resolve this problem.
    Feb 2009
    I've had mine for several years without problem but my vehicle is a D90. A fine piece of kit as far as I am concerned. Worth every cent.
    If I had any issues, I would talk to Mulgo.
    KarlB
