Results 1 to 10 of 31
Thread: D3 Breakdown - Major Loss of Coolant
    Mar 2015
    Engadine
    OK -towing the van home from the south coast yesterday in my D3, I suffered a sudden and major loss off coolant resulting in many chimes, gongs and alarms followed by the engine stopping, steam coming from under the bonnet and water pooling under the car. Looking under the bonnet I noticed the expansion tank cap was loose to the point of nearly coming completely off. I haven't been able to have a detailed look to see if anything major has split or come loose, other than the cap, but my LR mechanic did say that these caps have been known to pop due to system over pressurisation from some other cause (water pump??).
    Got the car unceremoniously towed home (fortunately we were nearly home) but can't get it looked at until Wednesday. The car turns over but won't start. Not sure if it's due to fault codes needing to be cleared. I don't want to clear them however until I get it looked at. Let's hope it's not terminal .
    Oztourer
    MY05 TDV6 HSE, Buckingham Blue
    Front Runner Slimline II roofrack and rear ladder, Safari Snorkle, Mitch Hitch, Traxide D3-DU, Bushman Fridge, Icom IC-440N UHF, Hema HN7, Tyredog TPMS, GVIF and reversing camera
    Narangga's Avatar
    Jun 2008
    McMinns Lagoon NT
    Certainly hope it's not terminal for you.
    The wait will be painful too.
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    Mandurah WA
    This part Thermostat Housing Land Rover Discovery 3 TDV6 LR073372 is common point of failure so one of the first areas to look for leaks.
    Yes just had min replaced proactively as it was starting to,look a bit sketchy.
    Mar 2012
    Gabbadah WA
    Quote Originally Posted by eddy View Post
    I carry one of these in my spares box .
    tasobb is offline Fossicker Silver Subscriber
    May 2011
    tassie
    Yep same here. Started to lose some coolant 3 days before the end of a 7 week holiday to SA and northern Vic. Didn't mention it to the better half.
    Got home to Tas OK and found the housing had cracked. nice and easy to fix.
    Aug 2010
    Question: where on the part do they normally crack?
    2014 SDV6 HSE - LLAMS, Tuff Ant Tree Sliders, Tuff Ant 18" rims, Nitto Ridge Grappler tyres 265/65 R18, Custom Lipo4 battery, Custom Drawer storage system https://www.box.com/s/jem0ilac3cner2mexq64
    Narangga's Avatar
    Jun 2008
    McMinns Lagoon NT
    Mine cracked where the red line is. Lost about a litre of coolant a day for a few days and fortunately didn't split properly until it was under a pressure test in the workshop.
    I would think that they may let go anywhere due to becoming brittle with the continuous heat.
    Cheers, Dale
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    Jul 2012
    Perth- South of the River
    I thought the earlier design was prone to failure but that issue has been fixed and the current design is OK.
    Can anyone confirm?
    Gone 05 D3 ARB Front Kaymar Rear Winch E-Diff LRA Tank Dual Battery
    Current 2015 SDV6 SE. Tow Pro Mitch Hitch Llams C/motives 70ltr w/tank 2 x comp Traxide BMS-2 x Aux 150w Solar Uniden Engel ARB drawer F/Runner rack Light bar
    Narangga's Avatar
    Jun 2008
    McMinns Lagoon NT
    Quote Originally Posted by Dagilmo View Post
    Can anyone confirm?
    I can't confirm that but I do know my BIL has a replacement engine in his 2011 3.0L D4 due to the original unit on his vehicle failing about 12 months ago. It was made out of plastic like my new one is.
    Cheers, Dale
    Previously Enjoyed:
    2000 D2 Td5 - plus!
