well you can go to almost any diesel specialist for work, and the filter number will be available through your local super cheap and repco the generic ryco number (and this does depend on which filter housing and setup you have is) R2390p
basically in the configuration you have its about the same as one and a half 4bd1-t's but its got a torque impulse at 120 degrees as opposed to 180 degrees so it wont lunch gearbox input gears quite so quickly.
do you have a specific question?
