Results 1 to 10 of 19
Thread: Drinking Fuel
    Jun 2015
    Bendigo, Victoria
    Drinking Fuel
    Hi all it has been a while. I've been playing with my new toy. A new caravan.
    The tub tows like a dream and the service station owners rub their hands together when they see me. Last trip I got 30L - 100km. without the caravan I'm getting 14L-100km. Will a tune up help or should I just enjoy the ride?
    Sep 2012
    Adelaide Hills
    how heavy the caravan?
    Current Cars:
    2013 E3 Maloo, 350kw
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    2002 VY SS Ute, 300kw
    2002 Disco 2, LS1 conversion
    Adelaide - Torrens Park
    That sounds about what my Dad used to get towing his big tandem axle van with either his 4.0 or 4.6 P38s. In comparison his TDV6 Sport towing a similar van uses under 20l/100km.
    Jun 2015
    Bendigo, Victoria
    2.200 t with a maz ball weight of 200kg
    Feb 2010
    Townsville, QLD
    Are you towing in 3rd or drive? Might be revving too low in top cog and labouring the motor.
    Also, are all the tyre pressures right?
    I returned high 18's/100km in mine when towing 4t, so 30 is very high.
    Keithy
    Jun 2015
    Bendigo, Victoria
    Towing in drive. But as you can see I'm towing a brick.Do you think a wind deflector would help.
    Jun 2015
    Bendigo, Victoria
    Sorry picture didn't work.
    Feb 2010
    Townsville, QLD
    Perhaps! More caravaners here might give some insight. If you get the chance to tow in 3rd, give it a try and see how you go. That's the only advice I can offer!
    Keithy
    May 2003
    On The Road
    3thousand revs Vs 2400,,
    at 100 kays the RR is bloody close to peak torque.
    I get 3.5 kays per litre on gas towing 2T
    4L? 4.6? tired? fresh? Thor? the other one?
    Jan 2011
    Burpengary, QLD
    I only had a small van 1.5 tonne but I found it much easier in sport mode on the gearbox helps it keep the revs up on the hills, might be worth a try.
