Thread: What Model and Year is best? (Budget)
    wobytinsor Guest
    Post What Model and Year is best? (Budget)
    Am looking to buy my first 4wd, to be used for both city driving but will also be used for overland and proper 4wd. After much research i beleive i have found the Defender 110 2004 to be best, but with a budget of around $20,000, im not sure whether this model and year would be best. I would prefer to stay under 20,000 as with the left over money i will buy recovery gear and what else is needed (and doesnt come on the defender im buying since itll be second hand).
    If anyone could provide me with any help or tips to what model and year is best and what the issues are?
    DiscoMick Guest
    Quote Originally Posted by wobytinsor View Post
    I'm not sure what you mean by 'best', but I assume $20,000 will get you a Td5 Defender 110.
    It's not as good as a later Puma with the six-speed manual (in my opinion, some might disagree), but if you get a good one it should be fine for what you propose.
    If properly maintained ( e.g. keep the oil out of the wiring harness etc.) the Td5 is a good engine and can be chipped to go pretty well.
    Obviously, the lowest mileage with the best service history you can find is the way to go for lots of happy motoring.
    Just bear in mind it's a truck, not a plush car, so if you accept that, it's a good thing.
    Dec 2014
    FNQ
    Quote Originally Posted by DiscoMick View Post
    That made me laugh almost uncontrollably. Problem is, it's 100% fact.
    Apart from what Mick said above, I would possibly suggest that you look at buying one that someone else has already made the modifications to.
    It also depends on what your target terrain will be. If you're doing mostly road work, touring and not much serious offroad, you may be better off in a disco? They have more comfort and appointments inside, that's all.
    We all have differing ideas of what constitutes our idea of the 'perfect' overland vehicle - in my case however, the missus would not accept a Puma as something she would even sit in, so we compromised and I got the next ugliest version, an RRC.
    If you're trying to get a late model, make sure it's been looked after, and try and find one already loaded with the accessories or mods that you plan. It will save you thousands.
    Roads?.. Where we're going, we don't need roads...
    MY92 RRC 3.9 Ardennes Green
    MY93 RRC LSE 300tdi/R380/LT230 British Racing Green
    MY99 D2 V8 Kinversand
    Judo's Avatar
    Judo is offline ChatterBox Silver Subscriber
    Feb 2012
    Parkdale, Melbourne
    Just a thought from me too - Are set on a Defender? Discovery's are much cheaper for same year and engine. They're also shorter wheelbase (good for 4wd'ing and parking) and more refined for city driving.
    If you want a Defender (and fair enough) a td5 is achievable for that budget but won't leave any cash spare. A TDI (95-99) in good condition will leave you a few thousand spare. Unfortunately the problem with any model Defender is they're not overly common in good condition for sale. It's supply and demand, which is why some of us are suggesting a Disco as a first purchase. My first 4wd is my current TDI Disco and it's been a great first 4wd.
    Good luck.
    - Justin
    '95 Disco 300TDI - sold
    '86 County 110 Isuzu
    2006 Range Rover Vogue td6
    Jun 2010
    Central Coast NSW
    I'll third the disco option. (Defenders are great but hard to find, and much more expensive than a similar vintage disco)
    You could get yourself into a 2000 td5 manual disco with 170k km for $11k. Its a fairly simple mod to activate the centre diff lock, and that leaves you $9k for mods. Theres second hand stuff coming up every now and then too. And plenty of info on here
    Dan
    Feb 2010
    Sutherland Shire, Sydney
    As mentioned, $20k should get you a TD5 Defender. I wouldn't get too hung up about the year model - service history, Kms and condition are much more important than the year model. Research common rust locations (there's plenty of information on this forum) so that you know where to look.
    Having said that, be aware that in about 2002(?) they changed the rear diff. Some here love the Salisbury diff that was in the earlier models. The newer diff gives more clearance but is regarded as being a weaker unit. Also about the same time the dashboard got remodeled.
    I'd Rather Push My Land Rover in QLD Than Drive A Toyota in NSW
    Hi Wobytinsor,
    They are out there, I will be picking up my 03 Td5 Extreme this weekend, it's loaded with just about all the big ticket off road items like F&R lockers, axle upgrades, LR Tank, roof rack, bar winch, suspension and way more, it has done 260K but has the best service history on any vehicle Ive seen by the same LR specialist all it's life, plus the original owner is "anal" with maintaining to a super reliable state. While it doesn't mean that something wont go wrong it does give me confidence that everything possible has been done to keep it at 100% so there would be no more I could have done to it myself.
    And I managed to get it for under the $20K budget you have set, I'll probably spend a little bit on it changing or adding a couple of small items for personal choice but that is about all, other than that it's ready to travel around the country or dare I say globe.
    I was probably lucky that it popped up just when I started my search and it was the first one I actually took the next step from just reading the adds, and I must say I'm glad I did. They some things are meant to be
    Looking forward to many years behind the wheel and many travel stories to tell.
