Results 1 to 9 of 9
Thread: 4BD1 bypass filter location? 4x4 Perentie GS
    Nov 2015
    Victoria
    Hi,
    Where is the bypass filter on the 4BD1 engine in the perentie 4x4 GS cargo's?
    About to do my first oil change on the Perentie, in somewhat of a shorter time than expected (work on call and have been called up tomorrow)
    I have a pile of assorted filters matching all the part numbers needed. One of which appears to be a bypass filter.
    Ive located the main oil filter - but can't see a bypass filter anywhere.
    The diagrams I have indicate that it should be below the main oil filter - but it is not.
    The thought has crossed my mind that I may have some variant that does not require this - as the ryco book lists these filters as for the 4BD1T - so maybe it's a turbo related thing?
    Feb 2014
    Quote Originally Posted by dranoweb View Post
    Hi,
    I think the 4bd1 in the civilian county and series 3 stage 1 had dual oil filters.
    AFAIK the 4x4 Perentie's all have a single inverted oil filter Isuzu part number 8-94321219-1. I don't think Ryco makes an equivalent.
    Try Landybitz, they have the Isuzu filter on Ebay.
    Regards,
    Phil B
    Custodian of:
    1974 S3 swb wagon (sold)
    1978 S3 swb canvas
    48 749 '88 4x4 Perentie
    1985 County with 4BD1T
    Nov 2015
    Victoria
    I have the following filters on hand:
    Ryco Z155X
    Ryco Z333
    Ryco Z169A
    Apparently the Z333 is an equivalent to the fleetguard LF3522
    at time of writing, I'm unable to verify if either of these are correct, but it would seem to be that way looking at other posts in the forum.
    Nov 2015
    Victoria
    Just did a quick lap around town and found a Nippon "max" Z419
    also has part numbers "WZ419NM" AND "MO-325"
    same diameter as the original but about a 3rd shorter.
    Guess this means oil pressure may be a tad higher.
    I quoted the isuzu number you gave me, and check the size of the Ryco one I have, the ryco is about 1/3 the length of the original.
    As it's imperative I change oil tonight, I'll use whatever is biggest and fits.
    Hay Point
    Ryco Z155X
    Ryco Z333
    Ryco Z169A
    That's a turbo engine filter set you have there dranoweb. Neither of those oil filters will fit the 4x4. The Z169 fuel filter will fit. The 4x4 in the perentie and late civilian Isuzu county had a single inverted screw on filter - the earlier ones had an element type single oil filter. Have a search on here and you will find the correct number for the oil filter. Normally I could help you but nowhere near my parts books atm.
    Cheers......Brian
    1985 110 V8 County
    Nov 2015
    Victoria
    I popped the hood and compared the above to my existing.
    diameter wise looks the same, length is about a 3rd short.
    I quoted Isuzu part number 8-94321219-1 at an R&E auto desk, they handed me the above filter.
    Brisbane, Queensland
    I popped the hood and compared the above to my existing. diameter wise looks the same, length is about a 3rd short. I quoted Isuzu part number 8-94321219-1 at an R&E auto desk, they handed me the above filter.
    I have the same part number. The previous number is 8944160690. Pic below of the 4x4 filter set up.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Jun 2014
    Waitakere, New Zealand
    I have these numbers for oil filters:
    - Isuzu 8-94321219-1 (Oil)
    - LR AYG585 (Oil)
    - Donaldson P550422 (Oil)
    - Fleetguard LF3642 (Oil)
    I also made this list of washers for when doing oil changes, it might be useful to you.
    Replaceable Washers:
    Gearbox Oil Strainer - FRC4810
    Gearbox Drain Plug - FRC4808
    Gearbox Filler Plug - FRC4835
    Transfer Drain Plug - FRC4810
    Rear Diff Filler Plug - FRC4835
    Nov 2015
    Victoria
    Very handy info guys.
    Ive done the major oils, but ill stock up on genuines later on.
    Appreciate your time.
    And didn't know the gearbix filter was replacable.
