Results 1 to 10 of 13
Thread: LT230 intermediate shaft
    Jun 2008
    Drouin East, Vic
    Have just completed a reco of the LT230 in my Puma 130. Chief reason for the job was a leak from the intermediate shaft front O-ring. As expected, the bore was slightly oval, thus the O-ring never stood a chance. Hopefully this is a more permanent solution than just fitting a new O-ring and hoping for the best;
    Bored the housing out .600" oversize and made a bush out of some 4140
    The bush is a .001" clearance fit on the shaft and a press fit in the enlarged housing bore.
    http://www.aulro.com/afvb/images/attach/jpg.gif
    Pressed in with a little loctite 640 for good measure
    From inside the case:
    http://www.aulro.com/afvb/attachment...1&d=1455360054
    A few hundred Ks on it thus far and bone dry (touch wood). Also much quieter with the new bearings, got rid of noises I hadn't even realised I had.
    Have to do the same job on a mates 110 in a couple of weeks, I expect his to be much worse than mine.
    Hay Point
    Nice job!
    Cheers......Brian
    1985 110 V8 County
    May 2015
    Near Fremantle, WA
    As a fitter and machinist and hydraulic technician, I can appreciate the effort that has gone into this job. Getting it done right, and fixing the issue once and for all is definitely the way to go.
    Love your work
    Torres Straits
    I'm Always wanting to learn mr POD. What was your rationale for not putting a shoulder in the bush and step in the case?
    I too did this job, used 4140, that was about 18months ago ago still no leak.
    Following Noel (ancientMariners) lead I made a stepped bush a light press fit and also used locktight 640 at time of fitting.
    Kind regards
    Steve
    May 2006
    Woolgoolga
    I need to do this to mine, if I only had the tools and skills! Great work Peter
    Very nice.
    With the bush that far over the nominal size Im going to guess that it shouldnt need stepping to hold it in place, if its positioned correctly the flanges from the gearbox and Tcase foot mounting bolts should back it up.
    I kind of always wondered why it was never setup to step from the inside.
    Jun 2008
    Drouin East, Vic
    Hi fellas, thanks for the replies- I'm certainly not the first to do this and it is far from an original idea on my part, just nice to have the gear to be able to do these kinds of jobs. I'd hate to be paying a machine shop to do it.
    With regard to stepping the bush, I'm prepared to stand corrected but I just can't see the necessity for it; the shaft should not move in the axial plane at all once installed thus there shouldn't be any axial load on the bush as far as I can figure. I guess time will tell. Would be simple enough to do, but, as has been hinted at, from which direction to step it? I pulled this bush into position from inside the case as the outside offers a flat surface to pull it up to, no more science to it than that.
    Jun 2008
    Drouin East, Vic
    Quote Originally Posted by Vern View Post
    I probably still owe you a favor or two Damien, why not bring your housing and shaft down to me when you have it apart and we can sort it out, perhaps leave it with me for a week or so, I'm still a bit slow with the machining for a while-u-wait service.
    May 2006
    Woolgoolga
    You owe me nothing Peter, but if your willing i'm happy to pay for it.
    Apr 2011
    Dungowan
    Really need to do this with the case in my rangie. It leaks there, and guessing with over 600k on it now the chances of just replacing the o-ring for a fix are quite slim.
    How is the setup on the mill bed? Just clamp down and good to go, or packing required?
