You asked for thoughts and opinions, so I suppose you are prepared for some disagreement about what is necessary or even what is desirable.
My opinion (for what it is worth) is that Land Rover make a very capable vehicle and while it can be modified to improve its ability to perform in one area, often there is a downside to the modification.
For a start, most things you add will increase the weight of the vehicle, so you will have reduced your useful payload or created the need for a suspension upgrade. Strengthening one component often just has the effect of moving the weak point from somewhere that is easy and cheap to repair, to another component that harder to get at and more expensive.
Then there is the cost to consider. There may well be occasions when the money spent on something like chrome plated twin overhead dipsticks might have been better spent on a brand new set of standard size tyres before you set out on the big trip.
Some Defender owners do all the things you have described with few if any modifications and they do it in comfort and safety.
It seems to me that some people start with the assumption that it is compulsory to heavily modify the vehicle and need to be persuaded that the proposed mod is unnecessary. At the other end of the spectrum, you have those who are quite impressed with the vehicle as it came out of the factory and need to hear some fairly persuasive arguments before they will spend big money for a small benefit.
You can probably guess at which end of the spectrum I sit.![]()
