Results 1 to 10 of 24
Thread: Starting vehicle after 12 months
    May 2015
    Victoria
    I started working on my p38 approximately 1 year ago. Stripped top of engine, new engine mounts, heads tested cleaned gaskets etc. I am almost finished refitting and ready to start engine. Are there any steps I need to take? or anything to look out for? Do I need to do anything with the fuel being in vehicle for so long?
    Feb 2013
    Gosford, NSW, Australia
    Hi
    I imagine the fuel will be pretty stale now, maybe you can dilute it with fresh stuff?
    Fully charged battery and the best of British luck
    Steve
    Feb 2010
    Townsville, QLD
    I'd imagine you might need to prime the fuel up if it doesn't fire straight away, otherwise, should be good! As Steve said, probably best to chuck some fresh fuel in the tank too.
    Keithy
    May 2010
    Mindarie, Western Australia
    It a p38, just turn the key and it will start straight away
    After double checking and triple checking all the connectors as well as the spark plug lead order!
    Steve and Keith have covered the main potential problems. I'd personally put some 98 octate in the tank to bring the average octane up again, turn the ignition to the on position for a few seconds to let the fuel rail pressurise then turn the key to the start position and enjoy listening to the beautiful v8 burble.
    Gary
    2007 Range Rover Sport TDV8
    Modified 1996 p38a HSE sold
    Nov 2015
    Black Rock
    Hi Anthony,
    Three things:
    1. Radiator If you haven't done it recently, I'd strongly advise you to have the radiator flushed. Even from this distance, I'll bet that it is at least 20% blocked! Don't rely on an observed apparent flow, I've seen many that looked OK but turned out to be up to 50% blocked.
    The radiator in a P38 is easy to remove, but due to the plastic headers can only be safely flushed and repaired a few times before a replacement is necessary. Don't allow the repairer to block any leaking tubes as the motor needs all the cooling it can get from the somewhat under sized radiator.
    2. Central locking Make sure you leave the windows open when you connect the battery. Or if the windows are up, leave the front doors open and make sure you lower the front windows before you shut the doors. If you have the doors shut and the key in the ignition when you reconnect the battery, the alarm ECU may think the car is being stolen and lock everything up and sound the alarm. You can stop it by disconnecting the battery, but then you are locked out of the car!
    Just be prepared for this.
    3. EAS The EAS will start the vehicle compressor to fill the 9 litre air reservoir and airbags. This could take up to 15 minutes. If you have a compressor handy (with dry filtered air) and the necessary fittings, you can partially pre-fill the reservoir and each airbag. This takes the strain off the vehicle compressor as it only needs to run for a few minutes.
    Once you are up and running, I'd give serious consideration to completely flushing out the ABS system with new brake fluid. Just sitting around, the hygroscopic fluid will still have absorbed moisture from the surrounding air. Make sure the place you take it to knows how to bleed the complete system, not just the calipers. It's not hard to do yourself with a mate if you follow the manual scrupulously.
    Best of luck,
    Don
    2013 D4 expedition equipped
    1966 Army workshop trailer
    May 2015
    Victoria
    Much appreciated thanks Don. I can recall reading that the vehicle needs to be driven up onto curb to help coolant flow, air pockets in lines. I'm not sure exactly my memory doesn't flow that well. Have you heard of people doing this?
    Jul 2014
    Anthony it might pay to check the hose that flows from the radiator to the expansion tank.....after a year it could have some sediment.
    2000 4.6 HSE Alveston red
    2007 307 xse peugeot
    1974 xj6l jaguar
    Feb 2010
    Townsville, QLD
    I've heard the "raise the front while bleeding" trick before. I've not used it though. Never had a problem bleeding the air out on my flat driveway. Follow the rave instructions and you'll be fine!
    Keithy
    Nov 2015
    Black Rock
    Agree with Keithy. Fill it slowly as per the manual and let it rest awhile between fills.
    Dec 2015
    Ballarat ,Australia
    Smile
    I would also have a look around the drivers side carpet at just in front of the console for any water staining or leakage from the heater core...I have a 97 4.6 HSE and a98 4.0 SE that have both sat around for over a year each...the HSE is fine ,however I ran the SE the other day ,and sure enough it started leaking from the core..worth checking for sure!
