Thread: HPFP belt- Change or not ?
    Ean Austral Guest
    Gday All,
    I am changing my oil pump and timing belt at about 132,000ks mainly because a car close to my VIN on the UK site had the tensioner break off , so to put myself at ease I will do it sooner rather than later.
    I am tossing up whether or not to do the HPFP belt as well , but in theory it should be fine for another 30,000ks. Its a separate job so in 2 minds
    Thoughts ?
    Cheers Ean
    Williams West Aust
    I would do it whilst you are at it.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    preventative maintenance is not preventative if you don't do it until after the component fails.
    Narangga's Avatar
    Jun 2008
    McMinns Lagoon NT
    From what I have read most others usually do it at the same time Ean.
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    Jul 2013
    Its a pig of a job so get it out of the way early If I every needed the body off on my disco that belt will be getting done at that time regardless of how long it is until it need to be replaced!
    For the record when I changed mine, the HPFP belt condition was significatly worse than the timing belt. I belive this is due to the left bank exhaust passing over the top of the transmission directly below the belt so the extra heat dosent do it any favours.
    But on the other hand, whilst its a critical belt to keep the engine running, its not critical if it fails (in regards to engine damage) as it will only kill fuel to the engine
    Shane
    2005 D3 TDV6 loaded to the brim with 4 kids!
    http://www.aulro.com/afvb/members-rides/220914-too-many-defender-write-ups-here-time-d3.html
