I also have not used extended mode since Gordons course but maybe I should practice. I remember the brake being required, I assume you followed the manual it might be the first thing the dealer asks. See the extract below.
EXTENDED MODE
If the vehicle's body is raised (e.g., by jacking)
or grounded in severe off-road conditions, the
system may automatically enter Extended mode.
Symbols in the raise/lower switch will flash and
the Message centre will display SUSPENSION
IN EXTENDED MODE. The suspension can rise
automatically to assist in clearing the obstacle.
Once Extended mode height has been achieved,
the driver may request additional lifting, if
required. This is achieved by pressing up and
holding the raise/lower switch for longer than
3 seconds, while pressing the brake pedal.
Extended mode is cancelled by pressing down
on the raise/lower switch or when the vehicle's
speed confirms that the body is no longer lifted
or grounded.
Cheers Craig
				2015 Discovery 4 HSE SDV6
2013 Nova Terra Sportz 22' van
2007 Sea Ray 185 Sports Bowrider
Specialised 29" Rockhopper
