Results 1 to 10 of 19
Thread: bizarre electrical issue
    jbe's Avatar
    jbe is offline Master Silver Subscriber
    Nov 2015
    Yass
    I have a bizarre electrical issue with my 2005 TD5 defenderand I hope this is the appropriate section to post my question. I also searchedthe internet quite a bit for this issue, but it doesn't seem to be common.
    Here we go: I noticed that when I honk the horn in theDefender for more than three seconds (or thereabouts) the windscreen wiper willcome on for approx. 30 seconds and then stop again.
    I am not sure where to start diagnosing the issue as thehorn and wiper circuits shouldn't have any common point.
    Any constructive input into my problem would be greatly appreciated.
    Joachim
    Jan 2016
    southern highlands NSW
    Quote Originally Posted by jbe View Post
    Joachim
    check your earths for those circuits
    Garfield, Victoria
    X2.
    Almost certainly an earthing problem!!
    Lionel
    jbe's Avatar
    Nov 2015
    Yass
    Will do. Thanks for that. Do you know where the earth for the wiper motor should be? To my knowledge, the wiper motor was replaced before I bought the car three months ago. When I had a quick look at it, I couldn't see anything.
    May 2008
    Bundaberg Qld
    That, I think is your first clue.
    jbe's Avatar
    Nov 2015
    Yass
    Agree. Not what I wanted to hear . It's about the fifth time, I have to pull the dashboard apart for various reasons.
    Anyway, an earth issue would be easier to fix that a buggered wiring loom.
    Can anyone tell me if the wiper motor is supposed to be earthed directly (I couldn't see any earth wire when I looked at it last time), or if the earth cable goes back through the loom to somewhere else.
    Didge Guest
    It's the "character" coming into effect
    May 2008
    Bundaberg Qld
    IIRC, the wiper motor is supplied with (key on fused) power all the time and the 2 internal wiring field earths are switched. This gives you the 2 speeds as well as self parking when the wipers are turned off.
    Jun 2008
    Drouin East, Vic
    Perhaps an anger management course would help?
    As others have said, most likely an earth problem- the words 'bizarre electrical problem' in your thread title screamed 'bad earth' before even reading the post. I'd be looking for a bad earth on the horn rather than the wipers.
    JDNSW's Avatar
    I would look first at the earth for the column switches. For a start, its easier to access!
