Originally Posted by
POD
Hi Mike. I'm just on the other side of Drouin from you and you have no doubt seen my 130 around. 2009 2.4. It has now clocked up 210,000km, had 120k on it when I bought it.
I was a bit concerned about the increased technology but after this many km I would drive it across the continent tomorrow with no concerns.
2 issues I have had related to the engine; one of the wires to the turbo wastegate actuator was installed under tension and fractured internally where it enters the plug on the actuator. This caused limp mode intermittently and would have bee very difficult to track down without the nanocom.
The PCV or VCV ('pressure'/'vacuum control valve') on the injector pump can get sticky causing rough idle and occasional stalling, replacement requires resetting by a specialist. The diesel specialist in Warragul, past the saleyards, are a Denso dealer and did this for me with no fuss whatsoever. They also checked my injector flows and reported that everything seemed in excellent nick after
just over 200,000km.
I've just overhauled the transfer case and sleeved the intermediate shaft, the oil leak there probably affects 90% of LT230 boxes so definitely not a puma-specific problem. Biggest job I have had to do on the vehicle.
The intake system downstream from the turbo gets a bit oily and the MAP sensor needs a little squirt with carby cleaner occasionally. A catch-can would cure this permanently but it has not made it anywhere near the top of my 'to do' list yet.
