1st March 2016, 01:53 PM
Front Bar
G'day one and all , I have a winch bar from one of Australia's largest makers fitted to my 110 Puma . It is there latest style , still on sale ! My question is has anyone got the same winch bar , and have fitted a winch into it ? I have a X9 Superwinch , and it won't fit . It hits the bottom of the grill , plus a strengthening vain on the back inside the bar . Has anyone else come upon this problem ? If so how did you get over it ? When I phoned and tried to explain , I was fobbed off , very disappointing !!... Jim
1st March 2016, 03:20 PM
If it is from the manufacturer based in Melbourne then you will probably require the additional winch fitting kit or some of the components. I had the new style _ _ B Deluxe winch bar fitted to my previous Defender. In the winch kit fitting instructions it said that the bottom of the grill would need to be trimmed and a lower grill strengthening plate which was supplied with the kit fitted. There were also spacer plates provided in the kit. That was 8 years ago though. You need to check the dimensions of the winch.
I fitted a Warn 9.5 XP winch but did not fit the spacer or trim the grill as the winch fitted without modification. Even then it was a tight fit. The site says the bar will fit Warn and Magnum winches but mentions no others, although if the size and footprint is similar, other brands should fit.
My 2013 Defender has the older style bar fitted and there is plenty of room to fit with the winch, even with the spacer plates fitted.
I would give the manufacturer another call as not all the reps there know about Defenders and the products.
I have the grill strengthening plate in my shed.
Hope this helps.
1st March 2016, 04:59 PM
Thanks 4 Wheeler , I also have the older style winch bar on a td5 , as you say plenty of room all around , The X9 Super winch comes strait off of that truck , I was surprised I couldn't do a strait change over . The sales man I spoke to didn't know much about Defenders . I asked how do you get to the free spool lever on the Warn winch , when he said from the top , I knew this was outside his product range !!.. Jim ..
1st March 2016, 06:32 PM
#4
Not a problem Jim. Your comment jogged my memory as thinking back, if I had fitted the spacers to the winch on the current Deluxe bar, it would have provided more clearance for the free spool lever but I would have had to cut into the lower grill panel which did not thrill me at all. I rotated the free spool assembly on the winch housing to make operation of the lever easier. You do access the lever from the top but once again it is a tight fit to get to it and operate it. While I like the look of the newest bar, the old style is just easier to live with and offers better clearance in all areas.
2nd March 2016, 01:35 PM
#5
I agree , the older bar is far more practical , in access to spool lever , plus just being able to look at the cable . The Delux bar looks good but there are a few deign problems with it . Access to spool lever is a major issue , ok yes you can turn it around , even put it on the bottom . Who wont's to be fiddling under the bar in a bog hole trying to get access , plus being able to see how the cable has wound on is also important . I now have a bar that cost a lot of money , plus a winch that also cost a lot of money , and there not compatible . I think what I'll end up doing is either putting spacers in . ' I'll get them made up " or get the chassis brackets extended , to pull the whole thing forward by about 20/25mm . that should clear the front grill . Jim
