Results 1 to 8 of 8
Thread: TCM reset
    here
    TCM reset
    I was told from a dealer that in order to properly reset the TCM on my D4 that the diagnostics equipment had to be connected to the car whilst driven for one hour and that I was going to have to be charged an hour for someone to drive it.
    Sounds odd to me.
    Is this the dealer being difficult or is there some truth in this?
    NSW SW Slopes
    Most people just clear the adaptions using diagnostics then over time allow the gearbox to re-learn. However to do the job properly a sequence of short accelerations is required, going up 1 gear at a time before stopping and starting again then repeating the whole process multiple times. I have the documented procedure somewhere - I did it in my D4 after its rebuilt gearbox box was refitted.
    here
    Well there ya go....maybe I should learn to trust my dealer more..
    Williams West Aust
    Try using sport for a few days then return to normality.
    The vehicle will adapt/re-learn.
    Is there an issue you want fixed that requires the re-set???
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    here
    TCM reset
    Andrew,
    Good question, and yes there is. I towed my camper without a LED load resister meaning the car didn't know it was there. I've since got the parts to make the load resister and am not going to tow the camper until I assemble it. Since decoupling the camper (2tonne), the gears when slowing down feel a little harsh (actually that's not the right word....they change back a little early making it feel like a sports car)
    I was thinking that with a reset that will that.
    Dealer said it doesn't matter if the car detects a camper or not it will learn as it goes whereas I've read that the Tcm map changes when it detects a load.
    Caine
    NSW SW Slopes
    I would let it sort itself out - it wont take long.
    Sep 2013
    Whack it in sport drive it like you stole it for a week then switch back to D ? If you can TCM reset
    Williams West Aust
    Caine.
    Dont worry about it,it will sort itself out.
    I got a near new D4 as a loaner,it went like a dog shot up the arse,despite being exactly the same spec as mine.
    By the end of the day I had trained it to drive how I do,ie like an old fart.
    Andrew
