Thread: station wagon crossmember
    Here is a pic of a county SW crossmember. It bolts to an angled bracket on the end of the steel sill member. The bracket attaches to bolt holes on the back edge of the crossmember
    There are also bolt holes on the front edge that appear to have no purpose. Why are they there?
    JDNSW's Avatar
    No idea - mine has them too. Probably for some body fitting on a different body style, or possibly for a seat belt anchorage in a different jurisdiction.
    Brisbane, Queensland
    You have a key bracket missing. I have a spare set somewhere if your interested. Here's a pic of my 110. I galled these and every other chassis bracket during my first refurb.
    A similar cross member is on the 130. The front holes may be for the 130.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    The missing bracket:
    REMLR # 137
    Feb 2013
    Sunshine Coast
    Quote Originally Posted by rar110 View Post
    That bracket is in his photo?
    It wouldn't surprise me if they had holes both sides so that it wasn't possible that the welder on the assembly line could weld the top brackets on backwards
    Quote Originally Posted by Dervish View Post
    That bracket is in his photo? It wouldn't surprise me if they had holes both sides so that it wasn't possible that the welder on the assembly line could weld the top brackets on backwards
    Looking again, I think you're right. Either the bolts holding it to the x member are missing or its welded on.
    REMLR # 137
    Thanks RAR110
    Actually the pic is from a wreck. I do have the brackets and am modifying and galving it (much along the lines of yours)
    The bolts are missing in the pic
