Good Question Welshman
Ive never had any luck with the search and wouldnt mind a lesson myself.
With LPG,you would expect to use 10% to 20% more than the petrol equivelent,the savings are on the cost.
Another tip for you LPG users,buy your LPG as early in the morning as possible before the sun gets on the storage tank,the LPG liquid is actually denser the colder it is and you get more litres of LPG than you actually pay for.The bowsers are calibrated to measure the LPG at a warmer daytime temp.It also accounts for why your consumption varies so much on LPG between summer/winter.Also leave the car parked out in the cold not the garage for the same reason as above,you will get more litre volume in the same tank.
Goodluck
Andrew
