Results 1 to 3 of 3
Thread: rear tank capacity
    Mar 2015
    Kyneton VIC
    rear tank capacity
    Hi guy,
    does anyone know the capacity of the rear tank in a 109?
    With the price of fuel I dont want to fill it up to find out!
    Mar 2010
    Queensland
    12.97 MB
    Quote Originally Posted by barnfindseries3ffr View Post
    Hi guy,
    Hello,
    As far as I am aware the Series 3 FFR - that is making the assumption from part of your username - only had a single tank that is fitted under the driver's seat.
    If you have a rear tank it could be an aftermarket one or an optional extra that someone fitted or swapped out from something like a station wagon. It could also be a custom job too.
    If you post up some photographs someone may be able recognise the tank and give you an estimate. Otherwise it is a "how long is a piece of string" exercise. The old formula of length x height x width will give you some idea of volume
    Kind Regards
    Lionel
    Apr 2014
    Blair Athol, Adelaide South Aust.
    If it has a wagon tank it will be 16 gallons or about 72 litres.
    Cheers Rod
    Sent from my GT-I9507 using AULRO mobile app
