That's a first for me.
What model do you have?
There are small elongated holes on my rear wing panels. What are they for?
I DO know that the large hole on the LHS is for the spare wheel access
They are not standard, someone has drilled 2 holes there side by side which makes it look like an elongated hole - for what purpose I don't know.
Cheers......Brian
1985 110 V8 County
scrim hooks, bottom bracket mounts for illegal clark mast mounts, hootchi hooks, cam pole hooks temp mounts for shot sensors, temp mounts for marker lights mount points for AFV model panels that make a landrover look like an enemy tank. mount holes for side ladders tie points for cable anchors for remote radio mount ups. Tank phones,
Its a mechano vehicle, maybe theres another couple of vehicles out there with matching holes and they get bolted together for utlra wide 8x8?
you invent one thing in a list of things youve hooked up to the back edge of a landy.........
Congratulations, you have a Perentie that has been deployed overseas.
Google Perentie 4x4 cleaning instructions and you should find an ADF produced instruction for the cleaning of Perenties prior to AQIS inspection. Somewhere in there is an instruction to drill holes in that location to allow a pressure cleaner to access the area above the wiring protection plate rearward of the mudflaps.
Here is that doc
And again, the things you learn on this forum
apologies to Socrates
Clancy MY15 110 Defender
