Thread: RPM observations
    Mar 2015
    RPM observations
    Just took mine out for a spin after sucessfully reassembling the dash.
    Apart from the heater flap! which means I have to pull it all apart again
    anyways, I now have a Tacho installed and have made some interesting observations.
    Gear Speed RPM
    1st 35 2100
    2nd 20 750
    40 1850
    60 2100
    3rd 40 1600
    60 1600
    80 2100
    4th 60 1000
    80 1400
    90 1600
    100 1800
    It's interesting just how low revs are needed. I was really revving it out in 2nd, and at 2100 I was actually quite scared I was going to break something. The noise was unbelievable and starting to sound very metallic.
    Same as in 3rd at 80. 2200 seems to be the max RPM you would want to/can use.
    Someone smarter than me can probably do the math and work out how accurate the speed/rpm is. These speeds were taken from a GPS app on my phone (though the speedo is accurate to within 3-5 km - reads low). Tyres are same diameter as the 7.5R16 (235/85/R16)
    I'm not sure if it's possible to use revs higher than 2200 or so. I know I wouldn't like to be in it when you were doing so.
    <edit> I've tried to space those numbers out, but the spaces get deleted when I post???
    edit 2 > updated some numbers
    Feb 2013
    Sunshine Coast
    Sorry mate, but your tacho is way out.
    This graph is generated purely mathematically so it doesn't account for things like our tyres being a larger diameter than normal 235/85r16s, but it should still be very accurate.
    Mar 2015
    Interesting.
    It seems to read the idle speed ok. Wonder what's going on.
    Have to break out the manual and have a closer look.
    I didn't think it was right having a whole 1000 rpm not used.
    235/85/r16 has the same circumference as the 7.5R16 so they should not make any difference.
    <edit> fixed. was set for a different amount of pulses per revolution.
    edit 2 - It may be mathamatically possible to get a perentie to 133 km/hr. I would not want to be in it when trying!
    Now need to adjust the 1100 rpm idle.
    wait till you hear one engine braking in second at about 70...
    hmmmm the passenger hated the smell of burnt brake fade in the evening
    May 2006
    Woolgoolga
    Yep tacho is out. When its revving on the governor it should read about 3200
    Mar 2015
    hmm. I think I need new springs on the injector motor. can't get it to idle lower than 800. I can undo the bolt and leave a gap and the arm won't go back against the bolt unless I force it. Might be because it looks like it has always been idling high and I think there may be a bit of a ridge worn in the mounting plate.
    I assume you can get the springs from Isuzu. Have to go out there anyway to chase up an oil sump plug and gasket; can't find those for sale anywhere.
    Jun 2014
    Waitakere, New Zealand
    Quote Originally Posted by Chris078 View Post
    Interesting.
    Wait to you get a turbo, accelerating from 100 is great fun.
