Wolf wheels are rated to 2200KG but are only 6.5" wide.
Regards,
Tote
Hello everyone
Just wondering which are the best (strongest) steel rims in 16x8 with about a +10 offset. Because I have been doing a lot of searching and most of the rims are only 1200kg rated where the standard rims are 1390kg rated. Unless you can get mine spec rims for a defender which are 1400kg rated. Has anyone had any problems with the 1200kg rated rims on there 110 defenders.
Regards,
Tote
Dynamic D's are 1400 kg rating
'95 Defender 130 Single Cab
HS2.8 TGV Powered
98% of all Land Rovers built are still on the road.
The other 2% made it home.
Cost difference between Britpart and Genuine seals: £2.04. Knowing that your brakes won't fail at any moment: Priceless.
Just get wolf rims. They're the real deal.
If you do go with wolf rims or the tubeless copies? make sure your wheel studs are long enough these rims are a lot thicker
Do you know if genuine Wolf rims have a Dunlop stamp on them as well the part no. ANR4583
I have the extra thick wolf style rims on my 130 (tubeless) but no stamping of part no. or Dunlop which I suspect are copies I think these might be the same Land Rover Defender Wolf Tubeless Heavy Duty Steel Rim 6.5 x 16" | Wheels, Tyres & Rims | Gumtree Australia Clarence Area - Seven Mile Beach | 1058074738
