Results 1 to 10 of 30
Thread: Wiring Trailer Plug to Defender Td5
    Jannali - NSW
    :?: Bought a trailer plug the other day and was just wondering if I can there are special existing wires for trailers at a Defender Td5 I can connect the plug to or if I connect this plug to the normal lights (rear lights, break lights, indicator lights).
    Thanks for your help.
    Daniel [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]
    Re: Wiring Trailer Plug to Defender Td5
    Sorry mate, the factory one you just have to tap into the existing light wires to the back of the car [img]style_emoticons/<#EMO_DIR#>/sad.gif[/img]
     2005 Defender 110 
    Western Australia
    I think there is a special plug tucked into the rear RH quarter panel that the factory harness plugs into, if you are wiring it up yourself then you may have to remove the plug, (probably a factory "special" you can't get anywhere), and connect up by solder and shrink sleeve. Other than that get the factory harness and pay through the nose.
    RichardK
    Series IV Matrix Offroad Camper following our Discovery 3 with E Diff, BAS Remap, Mitch Hitch, Uniden UHF, Codan NGT HF, Masten TPMS, Proquip Compressor Guard, ARB Winch Bar, Milemarker Hydraulic Winch, 4x4 Intelligence Rear Wheel Carrier, VMS GPS with Rear Camera,
    Mate, I've got a factory towbar and wiring instructions down stairs. There isn't a plug, you have to tap into the existing wiring [img]style_emoticons/<#EMO_DIR#>/sad.gif[/img]
    Jannali - NSW
    Richard, I can confirm, there is no special plug. I was actually just worried about the indicator lights. Because two more lights are drawing energy I thought that the lights would flash a lot slower than usual.
    This came into my mind because if you have a broken indicator light the indicators are going a lot faster.
    But anyway, will tab into the existing wires
    cheers Daniel
    Toowoomba QLD.
    cheers Daniel
    If you reduce the load, ie remove a lamp or have one fail they will flash faster. If you have the trailer tell tale lamp fitted in your car, most do, it will flash once and then stop without the trailer attached. With the extra lamps on the trailer it will flash with the indicator lamps and indicate the trailer lamps are functioning correctly. If you have a blown trailer idicator lamp, or LED's fitted to the trailer the tell tale will not operate as the load is not increased.
    All the wiring on my Defender is clustered behind the rear right hand wheel.
    Trev.
    Western Australia
    I stand corrected, in fact it was on my Disco that I was told it was on......will have to have a look.
    RichardK
    Toowoomba QLD.
    The Disco does have a special plug behind the right rear tail lamp cluster.
    I had to cut mine off because they don't sell the plugs. You need to buy the towing kit.
    Trev.
    Jannali - NSW
    Thanks guys, sounds easy, will fix this next weekend.
    Daniel
    Jannali - NSW
    Okeydokey, I had another look under my LR and found the socket (part # YPC114850) I was looking for. Just next to the fuel tank on the driver's side.
    I do not know how much the appropriate plug (part # PC114860) will cost. I will just cut off the socket and extend the wires to my aftermarket trailer plug.
    As far as I could figure it out this is the colour coding:
    [list]Grey/Black: Left Indicator
    Red/Black: Left Light
    Grey/White: Right Indicator
    Red/Orange: Right Light
    Grey/Purple: Break Lights
    Purple: +
    Grey/Brown: Reversing Light
    Red/Yellow: Fog Light
    Black: Earth[list]
    Mulgo Pty Ltd
    Expedition vehicles & equipment
    69 Anderson Road, Mortdale NSW 2223
    p 0438 183 507 / www.mulgo.com.au
    Purchase your 4wd gear online:
    www.expeditioncentre.com.au
    follow us on facebook:
    facebook.com/expeditioncentre
