The bottom one will punch out - hit it with the punch close to one edge and push it in - once you do this you can use a pair of pliers to pull it out.
The top white one is an aluminium threaded plug - I would replace it as it will probably be quite corroded. Last one I did had to be drilled and chiseled out, then the thread cleaned up (use a thread file) then fit a new plug. I think it is 1 1/4" BSP.
If it's not a plug, I think it could be a disk - I think there were a couple of different ways these were done depending on the year. I'm sure someone else maybe able to clarify this.
They look good but will corrode inside out. If the 1s under the rockers go it fills your sump with the coolant!! The rear welsh plug can be either a disc or a cup type, have seen them both on same year motors.
