Results 1 to 10 of 15
Thread: Suspension on bump stops
    May 2006
    Ulverstone,TAS
    Hi all,
    Need some HELP urgently.
    I put car down onto bumpstops so I could get the compressor out easier for me.(bad back)
    How the hell do I get it back up to normal height and re-enable the system.
    Have iid tool.
    Compressor wouldn't go up or down when selected on dash, put a kit in from bagpipingandy.
    Thanks in advance.
    2014 Freelander SE TD4
    2003 Range Rover TD6
    92 disco tdi manual sold
    95 disco tdi auto gone
    Australia
    Have you closed all the doors?
    The SLABS ECU will not enable the system if the drivers door or any other door is ajar or open.
    May 2006
    Ulverstone,TAS
    Hi Strangy,
    Yep had all doors closed.. Me outside so it could do its thing, but nothings happening.
    EAS control is back on(iid tool)
    I tried to put numbers in to each side, but it would only do left front.
    Couldn't get any other corners up on screen?
    The left front never rose up.
    May 2006
    Ulverstone,TAS
    Checked both fuses, all good.
    When I put the rear one back in there was a slight hiss of air.
    Any other clues to get it back up greatly appreciated.
    Jul 2014
    west of Transylvania
    I worked on a tdv6 some time ago with my multivehicle tester and had the same issue, was on bump stops and no reaction to ignition.... everything went back to normal when i selected "reset(or restore) level zero" (or something like that i cant remember exactly) so if you have some similar function in your GAP tool try that route not to inflate bags one by one cos that's only for test purposes and the heights will not be stored anyway... and make sure all the fault codes are erased in the EAS ECU
    May 2006
    Ulverstone,TAS
    I'll try that in the morning sierrafery.
    Feb 2014
    double check you put all the pipes back on the right connectors?
    I did the same thing with mine despite taking photos of everything before pulling apart.
    May 2006
    Ulverstone,TAS
    Hi Chaybra,
    That was the first thing I checked this morning.
    One of the hoses(the smaller one) was not seated properly.
    Put it back in, cleared the codes and it started rising.
    Took it for a bit of a test down the back paddock.
    Up mode worked good. Went back to normal and then......
    Down mode didn't do anything.
    Will try down mode again tomorrow when I go down the shops.
    If it doesn't work I might have to get a new compressor.
    Feb 2014
    Quote Originally Posted by disco gazza View Post
    Hi Chaybra,
    What are the 3 lights doing when going down? What was the reason for removing in the first place?
    May 2006
    Ulverstone,TAS
    Middle light blinks then stays on.
    No lower light
