Hi Bob
Unfortunately I have no info to add to your query but as an interested observer of all things technical I was wondering what you were meaning by installing an engine brake. Do you mean the compression release type used in trucks that make the loud noise? Would be interesting to see if these would be legal as a retrofit. Also I know there are often signs in built up areas prohibiting the use of these types of brakes.
What type of brake controller do you use? Maybe an upgrade of the vans braking system might be more beneficial?
Good luck with it.
Matt.
Oztourer
MY05 TDV6 HSE, Buckingham Blue
Front Runner Slimline II roofrack and rear ladder, Safari Snorkle, Mitch Hitch, Traxide D3-DU, Bushman Fridge, Icom IC-440N UHF, Hema HN7, Tyredog TPMS, GVIF and reversing camera
