Results 1 to 10 of 13
Thread: Td5 fuel filter water sensor
    May 2015
    Williamstown, Victoria
    Hello, am I right in thinking that there is an electrical connector to the water sensor? The water sensor attached to the fuel filter.
    Julian
    Yes there is, but what are the part numbers? I find it hard to search on Microcat
    Build date 11th Oct 2003
    LROCV #1410
    Free Again Thanks Dan
    Quote Originally Posted by Bohica View Post
    Julian
    Yes it should have a plug
    Jul 2014
    west of Transylvania
    Better dont bother with it, let the filter with it's own plug and isolate well the sensor's wiring/plug to not touch earth, the sensor is too sensitive and just gives you unnecessary warnings, as long as you replace the filter at decent periods you dont need it, tha's why LR didnt even fit one to later modells, also it's connected on the pump supply fuse and it can go wrong to blow the fuse then you'll not know instantly why the engine is powerless or not running
    in a nutshell: IMO it's useless
    May 2015
    Damn, I just bought one, and the plug on the wiring loom is full of dirt!!
    Ah well, I might put it on just to see the light on the dash at start up.
    What fuse do I look at? in case it blows.
    Julian
    LROCV #1410
    Jul 2014
    The light on the dash would do the self test no matter if the sensor is there or not cos the self test for warnings is managed by the instrument pack, the involved fuse is F10 engine bay(same for fuel pump relay)
    Dec 2009
    Baldivis WA
    Not much use to you now, but my 2003 Td5 manual has the sensor fitted from the factory, but also the function of the dash light disabled. AFAIK the 2004 models didn't even have the sensor fitted.
    2014, MY14 Discovery TDV6, Fuji White (2018-Now)
    2003, Discovery 2a, Td5 Manual, Zambezi Silver (2012-2018)
    2007, Adventure Offroad Campers, Grand Tourer (2015-Now)
    Quote Originally Posted by kelvo View Post
    Why do you say that rubbish when my 04 has one fitted from new and the light functions aswell
    Dec 2009
    Baldivis WA
    Quote Originally Posted by rangieman View Post
    I'll be more specific now that I have checked, VIN numbers from 3A838204 did not have the water sensor fitted from the factory, according to Microcat. See screen shot.
    My 07/03 compliance plate (VIN 3A810XXX) has the sensor, but the dash warning light is disabled.
    I have seen a LR document somewhere on the internet that mentions this function being disabled and the the sensor being removed due to too many false activations. As yet I haven't found it.
    EDIT:- Found a thread that also mentions it being disabled, still trying to find the LR doc.
    http://www.aulro.com/afvb/discovery-...sel-light.html
    My vin is well after that
    Avoca Beach
    My 2002 has a sensor and the light self tests and it has never come on falsely or otherwise.
    Maybe because I change the filter every time I change the oil.
    Personally I think they are a great idea. Lots of people pay hundreds for a Waterwatch which is basically the same sensor fitted into a bowl!!LOL
    Regards Philip A
