What about checking the ball joints on the steering arm
 Master
						Subscriber
						Master
						SubscriberSo yesterday while doing a three point turn my steering very suddenly got notchy. Approximately every 180 degrees that I turn the wheel (at 9 and 3 or maybe 10 and 2) there is a moment of stiffness. There was no ongoing issue or warning or build up to this happening, just immediately got notchy during a short drive.
I've bathed the steering column universal joints in INOX which may have helped very slightly but I think I'm just getting accustomed to it. I've checked the steering fluid, no leaks, and the level rises up and down when I turn the wheel. With the front wheels jacked up and the engine off the notchyness is still slightly present every 180 degrees but far reduced.
Even though lubing the UJs didn't help I'm presuming one of them is the culprit. Before I order a new set is there something something else that I should check?
Niels
Snowy - 1998 300tdi Defender 110
Past:
The Toad - 1992 200Tdi Defender 110
The best way to loosen seized steering universal joints is to remove them from the vehicle and put them in a pan of engine oil. Heat the oil gently on a stove to around 120C, then let it cool overnight. This seems to dissolve the crud build up inside the roller cups.
 Master
						Subscriber
						Master
						SubscriberSo in the end it was the UJ on the steering box end.
It was so seized that I couldn't even move it with a hammer so I bought a new one.
Wasn't the ball joints but when looking for the problem I did notice that most of the steering slack seems to be in the ball joints; they're fairly wobbly, so those are definitely going to get replaced.
Thanks for the tips.
Niels
Past:
