Results 1 to 10 of 26
Thread: Help needed - Surging under full throttle
    Jun 2015
    Hey guys,
    Strongly considering buying a tidy '03 TD5 S with 200K KM. Full log book servicing and drives well.
    The only thing holding me back is under full throttle, the motor starts surging. It idles smooth and drives sweetly under normal operation. However, when you put the pedal to the metal, the revs start surging back and forth by maybe 300RPM or so. Doesn't seem to matter what speed your doing, but it definitely did it at 60km/hr and 95km/hr.
    It's at a car yard and I told him to have his mechanic check the injector harness for an oil leak into the ECU. All clean there. Then I mentioned the previous owner may have adjusted the wastegate and it could be hitting overboost (all knowledge gained from this forum, so thanks to everyone for that). Can't remember if he said the mechanic looked for adjustment there or not. The mechanic's first thought was MAF sensor, so he checked that and reported back all good.
    The car really is quite tidy apart from a few interior issues (drink holders stuck in, seatbelt pillar plastic cracked etc) but I can't bring myself to purchase it without having this problem resolved. But it seems like if they can't find the problem, they won't bother fixing it. So I'm really hoping for someone to give me some possible solutions.
    I'd love to be joining the club of disco owners, but need to get this one nutted out first.
    Cheers in advance for any suggestions. Have a good weekend.
    Jun 2015
    Also, the EGR has been blocked off, not sure if that has any relation to a surging problem. Just thought I'd mention it anyway.
    Bairnsdale enjoying the rural view no rooftops to see here
    i had the same issue with my car it went away when the fuel pump failed and I replaced it with a new vdo unit
    have a good one :D ken :wasntme:
    MY07 L320 RANGE ROVER SPORT MORE GOODNESS TO COME
    MY03 D2A TD5 EXTRA GOODIE ENHANCED :D now parting from life
    1996 D1 300TDI GONE
    08 ford ranger c/c
    WRECKING DISCOVERY 2
    PM ME FOR WHAT YOU ARE LOOKING FOR
    Brisbane,some of the time.
    Raplacing the MAF fixed mine,it was surging only at full throttle.
    Nov 2014
    Nirvana near Albany W.A.
    If the mechanic has the means to test the air flow meter then he should be able to read if the turbo is over boosting ( which is what it sounds like) , get him / her to put the hose from the intercooler pipe straight to the wastegate actuator , bypassing the modulator ( square thing with three hoses bolted near the bottom of the air con compressor), if the problem goes away get them to replace it, egr block off is fine.
    Ringwood, Vic
    I'd back in the MAF. Less than $250 and 10 minutes to replace
    D4 SDV6, a blank canvas
    Jun 2015
    Quote Originally Posted by wardy1 View Post
    Well I've taken a punt and bought the car, so I hope you're right!
    Nov 2014
    Disconnect maf to diagnose , free and 2 seconds to do ,
    If you need a boost modulator its about $65 and 10 minutes
    Would recommended a nanocom .... Worthy investment
    Enjoy your disco, auto or manual?
    Ringwood, Vic
    Quote Originally Posted by chilla View Post
    Enjoy!
    I got my replacement MAF from someone in Brisbane... in Red Hill? Send a message to Blknight, he'll be able to help you out.
    Jun 2015
    Quote Originally Posted by discorevy View Post
    just d/c and take it for a drive?? Wouldnt that cause all sortsa funky crap?
