Results 1 to 10 of 18
Thread: RRS TDV8 - Thoughts On Taking To Birdsville
    Golden Beach, QLD 4551
    Hi All,
    I am going to the Birdsville races.
    I have a 2008 TDV8 RRS and I am thinking of taking this. I would appreciate people who have done this trip thoughts on taking my car.
    Currently very STD apart from a CB and a dual battery system...as purchased with car. 205,000kms.
    Thanks,
    Chilly
    Aug 2010
    Which way to Birdsville?
    From the East, not a problem a normal road car is fine!
    From the West, more preparation is required crossing the Simpson.
    2014 SDV6 HSE - LLAMS, Tuff Ant Tree Sliders, Tuff Ant 18" rims, Nitto Ridge Grappler tyres 265/65 R18, Custom Lipo4 battery, Custom Drawer storage system https://www.box.com/s/jem0ilac3cner2mexq64
    NSW SW Slopes
    What size tyres? 265/50/20 are considerably more suitable than the original 275/40/20 for gravel roads.
    Currently running 255/55x19.
    Coming from Central Coast. Moree, lightening Ridge. Plan a small trip in to the Simpson. Just a day trip.
    Brisbane, Queensland
    It's bitumen road except for the last bit.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    No problems at all. It is a great trip and a great car to do it in. You might need to plan your fuel stops to make sure you don't get caught. If you have a roof rack might want to throw an emergency Jerry up there, but if not should still be ok if you plan it out. AT tyres would be an advantage and make sure you know how to jack and change a tyre. But it isn't a challenging trip at all really unless there is a lot of rain. Good that you have a UHF already.
    Make sure you get it serviced before you go and get them to give it a good check over looking for hoses, leaks etc and replace anything that looks like it is getting dodgy.
    Will want to drop tyre pressure if you go and have a play at Big Red so good to have a compressor, borrow one from a mate if you don't want to buy one. Also good to have a snatch strap and rated shackles and know where your recovery points are. Usually plenty of other vehicles out there so shouldn't be any worries.
    Mar 2012
    Gabbadah WA
    Quote Originally Posted by Chilly View Post
    Hi All,
    Thanks,
    Chilly
    A very standard V8 RRS is top of the wosa , don't need much else beside your radio or sat phone , you wont be lonely out there , If you have not already done so have a practice at changing a wheel .
    The practice tyre changing suggestion is a good one. It's easy to pick up a screw on the road.
    You should be fine with fuel. I did a trip back from Birdsville to Brissy in my Perentie, which only has a range of about 450 km when fully loaded. You should have a lot more range in a RRS. The tdv8 is great for a trip like that. We just came back from Lightening Ridge and Dirranbandi in the RRV tdv8. Very easy to take.
    REMLR # 137
    Jan 2014
    PNG
    Easy run, maybe a TPMS, small compressor, tyre repair kit. It's a good quality fast dirt road, both from south and east
    apologies to Socrates
    Clancy MY15 110 Defender
    Thanks all for the replies.
    I do have a Defender fairly well kitted out...so can borrow compressors etc.
    Interesting to hear about practising a wheel change....what is so special about this?
    Think Ill go and have a read of the handbook and Greames manual.
    Chilly
