Results 1 to 10 of 13
Thread: dual map ignition
    Feb 2013
    Ballarat,Vic,Aus
    dual map ignition
    Hi Guys,
    has anyone tried one of these ?
    Rover V8 LPG KIT MAF Timing Advance Propane MSD Autronics 40672 CNG Ignition | eBay
    seems quite cheap for the effort and design work that would have gone into it. It appears they are selling off old stock as there isn't any real market left for them.
    My old '92 Range rover runs great on lpg ('cos I have the ignition way advanced), but so poorly on petrol, if I ran out of gas, I'd need to stop on the side of the road and retard the ignition to make it drivable.
    seeya,
    Shane L.
    Proper cars--
    '92 Range Rover 3.8V8 ... 5spd manual
    '85 Series II CX2500 GTi Turbo I :burnrubber:
    '63 ID19 x 2 :wheelchair:
    '72 DS21 ie 5spd pallas
    Modern Junk:
    '07 Poogoe 407 HDi 6spd manual :zzz:
    '11 Poogoe RCZ HDI 6spd manual
    May 2003
    On The Road
    That module doesn't suit any of the 4 '92 RR options,
    it would take a while to check all the RR years
    Feb 2013
    Ballarat,Vic,Aus
    Are you reading the ebay advert? There is no details there is there ? They all have electronic ignition, and I think that's the module for the hotwire MAF sensor models
    I tried googling for details, but the manufacturer has removed them from its website.
    seeya,
    Shane L.
    Proper cars--
    Modern Junk:
    Feb 2013
    Ballarat,Vic,Aus
    They have put up the wiring diagram.
    This WOULD work right? Anything later than the flapper Rangies (ie: discos etc) use MAF sensor right?
    Buggered if I can understand how a MAF sensor influances timing though. It should influance mixture not timing
    seeya,
    shane L.
    Proper cars--
    Modern Junk:
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    The Maf does not control the distributor, which is what controls timing, bt vacuum and by centrifugal advance.
    I found this on a UK site, this gizmo replaces the ignition AMP on the distributers so that spark advance is changed.
    New New !!!! What is the "Advance by retard system")?.
    LPG can indeed be as economical and powerful as fuel but the issue is with the ignition timing and spark intensity due to the slower flame front of LPG, Either upgrade to a Mallory duel point. as above( Carb type only) Or fit our unique new retard by advance system (Electronic ignition types only) We have just released this devise that replaces the original ignition amp on (or separate from) your distributor, (we can supply it with a brand new distributor also) and allows you to set base timing to 18 deg. thus giving a healthy 38 - 40 deg of advance when on lpg this will be the answer to all LPG prayers, and what's better when running on petrol it retards the ignition back to std 8 idle - 28 deg. @4000.
    Feb 2013
    Ballarat,Vic,Aus
    Yes, I figured the later integrated injection/ignitions systems must run timing maps based on the MAF sensor input as well.
    The above one would be interesting....
    A&R Amp Advance Retard Igntion Power Pre Amplifer Rover V8 3.5 3.9 4.0 4.6 RPi | eBay
    $300 it is though... I'd be tempted to convert to megajolt for that sort of $$$ I rekcon for similar money I'd have a crack at one of these:
    Megajolt/E | Autosport Labs
    By the time you buy coil packs and trigger wheel you would be at similar $$$. You could always revert back to standard in a pinch (even on the side of the road) too.
    for now I'll leave it set to gas running. It certainly is a PITA though as it barely runs on petrol as I have the ignition so far advanced.
    seeya,
    Shane L.
    Proper cars--
    Modern Junk:
    Feb 2013
    Ballarat,Vic,Aus
    This seems to be the cheapest/easier way to get the best lpg/petrol timing compromise. AEB 549 ... Joker:
    AEB 549N Joker-N Timing Advance Processor | Tinley Tech
    I wonder if anyone sells them in Australia. They would be about $150.00aud delivered to your door from the UK.
    seeya,
    Shane L.
    Proper cars--
    Modern Junk:
    Feb 2013
    Ballarat,Vic,Aus
    Well I fitted up one of those AEB 549n units. Very simple, I just flicked it over to 8cylinder, 9 degrees advance, no advance on idle or over-run. I reset the timing to 8 degrees and fired her up ............. It sounded absolutely spectacular. I took it for a spin up the court and it revs out much more cleaning, smoothly and quickly than having the timing set to ~12degree.
    OK, that test is good, now what I wanted was it drivable on petrol ... 'cos it's downright bloody dangerous if you run out of gas........ Flicked it over to petrol and she died in the arse. Would rev ok in nuetral, but wouldn't run under load, certainly with the clutch out you can't rev it past 2000rpm ....................... Hmmm...
    So I took it home and bypassed the AEB unit and had the same behaviour .... Well bugger it all, I sure did mis-read the symptoms, I thought it was breaking down and dying as the igntion was far to over-advanced to run on petrol. I whipped the lid off the dizzie and check the weights and 'vac advance...... But she runs so incredibly sweetly on gas it simply can't be ignition.
    I struck something similar to this on an old Citroen CX before with a flapper type air flow system...... Which on that car I verified by unplugging the air flow meter and seeing if it would run .. which it did but poorly (as they must use a default map).
    Soooooooooooo, I unplugged the mass airflow meter, and the rangie will now run on petrol, kinda poorly but it will rev out and run on petrol. I swapped it with the mass air meter off the other car and had the same symptoms.
    Does this sound familiar to anyone ?? Is it a sensor unplugged somewhere ? The fact it runs ok with the air meter unplugged says the injectors and fuel system is flowing adequate fuel. Maybe I have a wire chaffed through somewhere. So if no-one has any suggestions I'm about to waste many hours following wiring back into the cabin and checking all the connections and plugs
    But hey, it's bloody lovely running on LPG
    seeya,
    Shane L.
    Proper cars--
    Modern Junk:
    Feb 2013
    Ballarat,Vic,Aus
    I just thought I'd add an update here. The car is absolutely transformed in the way it drives with that ignition processor. Idle is smooth and has a real v8 beat to it now. It hammers .... The difference to the cars running is amazing. I'm probably using only 2mm of throttle in all gears to keep up with the traffic, only it revs out much harder and smoother than it ever has before.
    I didn't expect an improvement when running on gas, I thought I'd get an improvement in the petrol running.... I'm extremely happy with the AEB unit. $150 very well spent!
    seeya,
    Shane L.
    Proper cars--
    Modern Junk:
    Two Rocks WA
    Hi Shayne
    Based your glowing report I have just ordered the dual advance joker from tinley tech.
    Can't wait to see what improvements in power and smoothness I get.
    I have been tossing up over many years to get one of these and now it's done.
    Brad
    Range Rovers Have Charactors inside them
    LROCWA Ex member 23 years
    1971 Series 2A
    2004 Discovery2a V8 Auto
    2003 Discovery2a TD5 Manual
    1982 4door man (sadly now gone)
    1989 Vogue auto
    2011 TDV8 Vogue
    What would life be without a Rangie?
