Does the actuator sound sick? Does it improve if car is still running (higher voltage). If not actuator related, mine got dusty and came good with a spray of lubricant.
Hi All,
The square button which opens the lower tailgate of my D4 is a little sticky and now takes two presses to open the tailgate rather than one. If I am lucky, sometimes I can open with one press.
Any thoughts for a simple solution? I fear its a dodgy actuator or similar.
Many thanks
Mario
Link to my D4 Build Thread
D3 2005 V8 Petrol
Mine did that for a month before failing, and I had to pull it all apart from inside the car, not fun
MY11 SDV6 HSE, e-diff, LLAMS, Snorkel, Rhino Pioneer Rack, DBS, BFG KO2 265/65r18, Mitch Hitch, GME TX3550s, GOE stuff....
To the upper or lower tailgate? Usually the upper tailgate actuator, located in the lower tailgate, fails. But it's the lower tailgate actuator that's controlled by the square button that the OP has issues with.
I haven't heard of cable breakages for the lower but the actuator could be on the way out.
D3 2005 V8 Petrol
What he said
Mark
Of all the things I've lost, I miss my mind the most![]()
2003 D2a TD5...gone...
2000 D2 V8...gone...
https://bymark.photography
What they said
Andrew
DISCOVERY IS TO BE DISOWNED
Snow White MY14 TDV6 D4
