Results 1 to 10 of 21
Thread: CDL sensor wiring on 2002 TD5
    Apr 2015
    Rockhampton
    I have just had a CDL fitted to my transfer case, but am unable to find the wiring and plug on the wiring loom to connect to the sender switch on the TC.
    Where do I look for the wiring and plug, or was the wiring not included in the loom for 2002 production vehicles.
    I am hoping someone out there has the answer.
    Cloughy
    Mar 2016
    North Lakes QLD
    Well I could be wrong (usually am) but, as the CDL was discontinued and removed from the transfer case altogether after 'mid 2000? then perhaps the harness was modified as well to delete the wiring no longer required.
    I'm sure someone with far more knowledge will way in and explain it better.
    Ray
    Apr 2015
    Rockhampton
    Thanks Ray, but I do think they retained the CDL engagement wiring in the harness - the wiring is still in the harness for the transmission temperature sensor (as I discovered yesterday whilst looking for the CDL circuit).
    Cloughy
    Feb 2009
    Newborough, VIC
    67.72 MB
    My 2002 model had the wiring for the CDL and the high/low switch.
    However, the new transfer case that was installed had no facility for the high/low switch, as it came from a different model land rover.
    I end up rigging up a magnet and reed switch onto the high/low gear selector lever underneath the leather thingy, then used the existing wiring. Five years later, I haven't had an issue with it. Anyway, good luck to you, it's a great bit of gear.
    PS. Don't forget to cut the wire at the ECU.
    2002 D2 4.6L V8 Auto SLS+2" ACE CDL Truetrac(F) Nanocom(V8 only)
    Apr 2015
    Rockhampton
    Thanks Biggin,
    All good with the high/low switch - all is as original, just the CDL sensor that I need to connect.
    Avoca Beach
    Look up my thread from a couple of months ago.
    The connector to connect the wiring is under the console below the window switches. I give the number in the thread.
    I added a switch to the window panel to enable start without ABS and HDC with the switch enable or with the CDL indicator + ABS +HDC with teh switch disabled.
    You cannot enable the ABS etc if started with the CDL engaged unless you turn off and restart.
    Regards Philip A
    Google down the bottom of the page.
    I am adding CDL to my 2002. ***** of a job
    or go to about page 3 of all my posts
    Apr 2015
    Rockhampton
    Phil,
    Thanks for your post and info, you have answered all my questions.
    I wont be able to attack it until late May or early June as I will be O/Seas, but will advise when I get back and have completed the job.
    Cloughy
    Cambewarra, NSW
    The 2002 (and later 2001) transfer case wiring loom does not have the CDL switch wiring fitted. You need to get a harness from a pre 2002 or 2003/04 model. 2003/04 models have two CDL switches. Note: The manual transmission harness is different to the auto transmission harness. For the CDL switching to work properly in conjunction with traction control, and not have to cut a wire, use the later version of the SLABS ECU from a 2003/04 model.
    Oct 2007
    Brisbane West
    I had it set up without the wire cut mod and it was a pain in the arse and also i never found a situation where having CDL locked and TC turned off was an advantage. Wire cut is easy and was a good mod. I had to use a switch (a second HDC switch as it happens) to tell the SLABS ECU that the vehcile is in low range. Mine is an 01 build and all wiring and connectors were there for CDL light switxh. Cheers
    Avoca Beach
    Just to be clear the wiring is fitted to the console, but not to the switch. You have to make up a small loom from the switch up to the console to the blue/green? and another to an earth.
    The 2001-2002 will work with traction control as long as you start the engine before activating CDL, or if you put a switch in the circuit you can start then press the switch.
    Regards Philip A
