Thread: pt# for hi/low pivot.
    Feb 2014
    upper hunter
    I can not seem to find the part number for the pivot bushes (nylon) and the restraining clip for the hi/low selector lever. It is on the side of the gearbox. The link is flat bar with a grooved stud welded on it and the nylon bushes then go on this stud and inside the pivot that is screwed it the side of the box. It is retained with a metal clip.
    Oct 2007
    Wantabadgery, N.S.W.
    Manofaus, have a look here. After you've chosen what type and age of your Defender, select your way through until you find the part shown. Click on the little number, and the part number will be revealed.
    Don.
    Feb 2014
    upper hunter
    I did try that but no good.
    Having said that I was looking for a pivot but apparently it's not...?
    What does lt77s mean? I thought they were all lt230s.
    Oct 2007
    What vehicle/year model do you have and what gearbox/transferbox? We need to know that in order to help you.
    I'll be away from the web for the next few days. Someone else will come by and assist if you put up the info I've suggested.
    Don.
    Feb 2014
    upper hunter
    Sorry I did find the part on lrcat as pictured. It's just that it was under a section without pivot even though I thought it was a pivot.. BTW td5 2000.
    Thanks again.
