2.2 Tdci Puma (in-tank) Fuel lift pump specs
Just hoping to get a gauge on the specs of the 2.2 Tdci Puma (in-tank) Fuel lift pump.
For those unaware, the 2.2 tdci in the 2012+ pumas have a fuel sender / lift pump (low pressure) unit in the diesel fuel tank, whereas the 2.4's have the lift pump as part of the HP fuel pump on the engine.
For the purposes of installing a second diesel fuel filter, any idea what pressure / flow one might expect from the in-tank lift pump? Fuel filters tend to be rated by the Litres per minute (or gallons per hour) flow rate, and pressure that is expected to be seen in the system (I presume this is to prevent the filter medium collapsing).
Also hoping to get the general consensus of whether running a secondary fuel filter puts additional strain on the lift pump, and whether this is a potential issue long term.
-Mitch
'El Burro' 2012 Defender 90.
