Results 1 to 10 of 11
Thread: Load capacity of folded seats
    Question Load capacity of folded seats
    Worried about potential damage to the 2nd/3rd row seats folded flat.
    I'm looking at transporting a rather heavy (80-100kg) object with a 450x450mm foot print over about 600km of dirt roads. I'll also have other cargo but nothing with this mass in a small area. The rest is tools, luggage and shopping.
    The item is solid and not fragile and will be tied down. My thought was to try and anchor it forward of the rear axle but this puts it on what I consider to be the least supported portion of the folded third row seats. I then thought about placing some board/ply over the entire area to distribute the load off/across the seat backs.
    Any suggestions? Never had this issue in the Defenders
    Jun 2008
    McMinns Lagoon NT
    Which direction is your travel with the load?
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    Jan 2012
    Don't think I would worry, as long as it is tied down, and not prone to "hop" up and down on one spot.
    80-100kg is a average person weight. 450x450 would be the footprint of an average derri're. The seats will take it.
    If you were super worried, wouldn't hurt to chuck a piece of ply underneath to spread load over a larger area. Your choice really.
    May 2003
    On The Road
    If its (only!) a 100kgs, tying it down properly will tell you where it will be. Axles dont enter into it. you need to stop forward movement at all costs,
    Williams West Aust
    Pedro,he is worried about damage to the seats below the load
    Derek,I would get a couple of sheets of plywood etc to spread the load.
    Note the filler panel at the sides of the seats is just that it wont hold weight.
    If you are really worried,remove the chairs,I ditched mine a long time ago.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Quote Originally Posted by Narangga View Post
    Is that a loaded question?
    Inbound so will know how rough it will be.
    Quote Originally Posted by SimmAus View Post
    That's where I got to with my thoughts. The seats are designed for that when unfolded though.
    Andrew
    Will possibly need the seats during trip before returning. I'm going to have a good look at the filler panels and everything tomorrow. I think the ply sheet is going to be my best option.
    I've had 500kg of concrete bags on mine with no ill effects!
    Having said that - throw some plywood underneath - spreading the load always helps!
    Having also said that - I've had a fully loaded fridge on one side only for over 3000km of absolute corrugations- and no issue at all.
    Jan 2008
    Lysterfield, VIC
    I wouldn't even have worried about 80-100kgs. I'm 90 and I wouldn't have thought forward or rear of the axel would have any effect especially with the car weighing what it does.
    If you are worried, and I would only do this to protect the carpet/mat, is to put the ply down as suggested.
    Dave.
    Hi.
    96 Disco 1 V8.
    99 Disco 2 TD5.
    LROCV.
    May 2010
    Brisbane, QLD, Australia
    Whatever option you use just don't let the load bounce on the folded seats as the latch mechanism can break.....been there.
    As suggested ply or something else to spread the load and stop any movement of the folded seats will work with heavy weights.
    Cheers.
    The axle position was as much an indication of where it will sit, I tend to put more accessible stuff at the tailgate. I don't have a cargo barrier in the D4 so everything will be packed securely. My D1 was an ad for why you use a Milford barrier (or similar) some years back so I am acutely aware of loads moving.
    Looking at the back of the Disco this morning I think ply and a rubber sheet under it will be the easiest. If I do it right I'll be able to net everything down as well as strapping the heavier items
