Results 1 to 10 of 27
Thread: Advice sort for buying a D2 at Auction
    Dec 2012
    Perth, WA
    So I know of a D2 coming up for Auction very soon. The last time I looked at it, it was locked but it has since been moved do I don't know now. I am kicking myself for not taking a picture of the VIN at the time.
    I know it's a V8 petrol, it's a manual (the part I really want). The interior has seen much better days and the back was full of what looked like cheap camping gear that looked like it was ready for the rubbish tip.
    The biggest problems I see myself having is I know it won't come with any keys unless there is a key inside the vehicle somewhere (glove box maybe). I know I can get a code from the VIN to get one cut and I can some how enter an emergency code to start it.
    I'm not too concerned about much else other than the gearbox but I'd like to get the engine running just so I can drive it around the paddock and make sure the gearbox is in fact good rather than go to the trouble of doing the conversion and driving out the driveway only to find 5th gear has had the possum.
    I'm hoping that I can flog off other stuff cheap just to make back the dollars it costs for me to buy it. Again driving it will mean I can confirm that the transfer case is working as it should all be it a small test. I think if I can confirm they are operatable I could get $250 - $300 for the LT230 and then similar each for the front and rear axles complete and that would near pay for the vehicle. I haven't searched at all but doubt petrol V8 engines are worth much. I might just build an engine stand and keep it to scare the neighbours (LOL). If I can get myself back to where I started $$ wise, I'll be able to put a new clutch and the like in.
    Happy Days.
    schuy1 Guest
    Joel, isnt yours a TD5? I think the spigot shaft on the V8 gearbox is longer, or is it vice versa? I am pretty sure the boxs are different some how. Would pay to check. But sounds a good plan
    Dec 2012
    Perth, WA
    Bugger, can I change the spigot shaft?
    Dec 2012
    Perth, WA
    Oh, I just found I had already been told the spigot shaft and bell housing have different part numbers.
    I'm still not sure on the exact difference.
    Dec 2012
    Perth, WA
    Maybe I can just use a custom spigot bearing and a V8 clutch?
    Dec 2012
    Perth, WA
    Because changing the input shaft is not an option at $400.
    Land Rover Parts - 5: GEAR - 1ST MOTION - L/R (R380)(Input shaft)
    Dec 2012
    Perth, WA
    deleted
    Dec 2012
    Perth, WA
    So the part numbers that start with FTC seem to be for a short bell housing R380 for early LT77 replacements.
    Part numbers that start with TUD for the Spigot shaft seem to be for the normal length bell housing. The TD5 being different to the V8 bell housing. I still haven't worked out if they are different length or just different tooth count. I'm thinking 21 tooth for the V8 and 22 tooth for the TD5.
    May 2014
    Point Cook, VIC
    Joel,
    Other than the 5th gear ratio, I thought gearbox in the D2 was the same. The R380 in the Range Rover is different to the Discovery.
    The bell housing, clutch, and flywheel are all different. Not sure about the master cylinder but I believe the slave cylinder is the same.
    David
    Dec 2012
    Perth, WA
    Quote Originally Posted by DiscoDB View Post
    Joel,
    David
    Thanks Dave,
    It's hard to sift through all the info. So many people talk about fitting the R380 in place of the LT77 so there are a heap of combinations.
    I think you are right that the V8 Disco 2 and the TD5 Disco 2 have the same input/spigot shaft. Just the 5th gear ratio is different.
    I should be right for a Bell Housing as I know of a guy who has gone the other way and changed his Manual for an Auto. If this all gets too hard I might just get the whole package from him. I think it would be easier to have a vehicle sitting side by side.
    I think I'll be best of to fit a new fly wheel and clutch at least at the same time of fitting.
    Happy Days.
