Results 1 to 10 of 29
Thread: Perentie Clutch bleed procedure.
    Nov 2015
    Victoria
    So... I drove all the way to work in 2nd today as I suddenly found myself with a barely usable clutch and no fluid in the resivoir.
    What size brake line spanner do I need,
    And more importantly, any tips on bleeding/diagnosing the clutch?
    Sent from my E6653 using AULRO mobile app
    Mar 2015
    did you find out where the fluid went? If you can't see any leaks between the master and slave cylinder, it's probably in the bell housing.
    There is a drain bung at the bottom of the bell housing you can remove to check (obviously keep your face out from underneath it when you remove the plug)
    You'll probably find it's the slave that has failed (seems a very common issue with Perenties due to them sitting for extended periods of time)
    You can get a genuine Lockheed slave for $90 or a cheapie for $45 or so.
    Bleeding is a bitch, prepare you left thigh for much pumping of the pedal and 45 mins of trying to get air out.
    If it turns out to be the master, I just replaced mine and can give you a few tips to save time and make it easier to replace. - Interestingly a genuine TRW master is cheap at $65!
    Nov 2015
    Victoria
    Still at work, unable to check yet.
    Trying to find a spare slave at present.
    Aussie Expat in NZ
    Replace the master at the same time - twice I've had them go in succession..
    Nov 2015
    Victoria
    update, have procured a replacement slave - with luck, will arrive tomorrow.
    No visible signs of external leaking so I'm guessing it's in the bell housing.
    I understand this is a common issue.
    looking at it, bleefing seems like it would be easier with the slave removed?
    Nov 2015
    Victoria
    Quote Originally Posted by flagg View Post
    I have neither the funds or time to do so immediately. I have one day to complete repairs in between work and other essential duties.
    I can't get hold of a master locally.
    I bled the existing slave tonight and got air and some of the dirtiest fluid i've ever seen.
    Clutch feels much better but I have oil weeping from the bell housing join, so I'm just doing some homework on which drain plug is safe to remove.
    Austpost says express shipping will have a spate slave here tomorrow, and I'm trading in my brownie points to knock off early to get a start done. Sat avo is deadline.
    Hay Point
    Quote Originally Posted by dranoweb View Post
    If you can remotely afford it, change the master at the same time. They are cheap and are used on many applications including box trailers etc. Approx $40. from memory. It will probably save you doing it all again shortly as they are a bitch to bleed. Remove the drain bung from the flywheel housing (15/16") and leave it out. Only put it back in when you are going to do some deep water crossings. Make sure you get the correct slave cylinder ( 1" bore). Cheers....Brian
    Cheers......Brian
    1985 110 V8 County
    Nov 2015
    Victoria
    This is what's coming out the slave bleeder:
    Nov 2015
    Victoria
    Checked the bell housing drain, very little emerged, but buildup on the plug the same colour as the junk coming out the slave bleeder
    Hay Point
    That's water contamination and oxidised alum combined. Pretty normal stuff.
    Cheers......Brian
    1985 110 V8 County
