Results 1 to 3 of 3
Thread: Roof rack mounts
    Aug 2013
    Howrah, Tas
    Roof rack mounts
    Hi,
    Finally finished making and mounting the roof rack.
    Used 12mm thick steel plate and 5mm plate for top. It was bolted down using u bolts and a single bolt at the rear end.
    You can see in the pictures. This project about $70 to make. Got drawing and measurement to make proper instructions later.
    Sent from my GT-I9505 using AULRO mobile app
    Jason
    Range rover l322 2002 TD6
    Is that an ARB rack that you've fitted?
    I considered a D2 spare wheel holder for my roof rack mounted spare but there's no way I could lift the spare up and over. I'm using a Y-shaped tiedown strap.
    Aug 2013
    Howrah, Tas
    Hi p38
    I got the rack of gumtree in hobart from d2 owner who hot the proper rhino rack he was after.
    Yes l used the disco spare wheel carrier and added a stud to the wheel stud pattern. And used hose clamps to the rack, keep it simple.
    Jason
