Results 1 to 10 of 18
Thread: Mirrors Dip in Reverse
    Feb 2016
    Why don't my mirrors dip down in reverse?
    The manual suggests they should.
    Llams shows settings correct.
    Am I dreaming they should?
    Vin
    Cheers Vin
    2025 D350 Defender 110
    Oct 2013
    Old Toongabbie, Sydney NSW
    Quote Originally Posted by rhinosm View Post
    Vin
    You have to set them up how you want them. From memory (it's been a while) you have the engine running, put the car in reverse and then manually, using the buttons adjust them to how you want them. Next time you put the car into reverse they should dip to the position you set them at.
    Martin
    Jun 2008
    McMinns Lagoon NT
    On a D3 it's in the SETTINGS on the message centre of the dash.
    Push the i button on the indicator stalk to activate.
    I actually don't have mine dip as I prefer to look at what I am about to run over rather than watch it come out from under the wheels
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    Mar 2007
    South Arm, Tasmania
    Quote Originally Posted by Narangga View Post
    Same here - I'm glad my mirrors don't dip in reverse.
    A couple of loan cars I've had from the dealers recently (Evoque and Disco Sport) both had dipping mirrors - I didn't like it at all. I suppose it might be different though if you also had a reversing camera and were in the habit of looking at the screen to see what is behind you - before you see it come out from under your wheels in the mirrors.
    Cheers .........
    BMKAL
    Oct 2014
    I am confused about how Llams fits into this function?
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    Feb 2016
    Good pick up Scott.
    Its the IID Tool. Too much technology.
    I was able to activate mirrors dipping.
    Cheers Vin
    Isn't it a trim level specific option?
    You may not have the control units to drive the function.
    Feb 2013
    Wamuran, Qld
    Agree with others that it's a function that doesn't appeal after experiencing it in a loaner Evoque.
    Sometimes gadgetry is there for no reason other than to confuse and mystify some, and bedazzle others.
    Ron
    2013 D4 SDV6 SE
    Jul 2009
    Hobart
    Hi,
    I dip the mirrors with the toggle switch to back up the drive at home. Pity it is only a Corolla.
    The Defender mirrors give a good view and won't adjust any way.
    Feb 2012
    Darwin
    FWIW I really like the function. I have set it up so I can see the rear wheels and bumper. I mostly use the rear view camera. If you increase reversing speed the mirrors will raise back to normal position and dip again when speed is slowed again.
    Cheers, Mungus.
    _________________
    MY14D4HSE, Nara Bronze, E-Diff, Vision Assist, Surround Cameras, LLAMS, ProSpeed Sliders/Compressor plate, Mitch Hitch,
    ARB Summit Bar, Runva 11XP, Traxide D3-DU, GOE Comp. Rims, D697 265/60R18, Rijidij RWC, Fyrlyts.
